Build fails to publish
It says
Publishing build https://hub.flathub.org/api/v1/build/59416
the build has failed
Api call to https://hub.flathub.org/api/v1/build/59416/publish failed with status 400, details: {'current-state': 'failed', 'error-type': 'wrong-repo-state', 'expected-state': 'ready', 'message': 'Build failed: 1 out of 2 checks failed (flatpak-builder-lint)', 'status': 400}
It looks like some flatpak-builder-lint check has failed, but I don’t know what is the issue
Hey,
it should now work, if you restart it.
We’ve added a new check for developer_name in the appdata, that wasn’t supposed to be active - but slipped through.
But it will be enforced at some point in the future. We first want to announce it and give everybody enough time to change.
Sorry for this.
Cheers
