I got Rust + Gtk 4 ( https://crates.io/crates/gtk4 ) working in the upstream (tar.gz file) / non-Flatpaked IntelliJ IDEA Community Edition IDE, but I can’t seem to get it to work in the Flatpaked one.
This is what I do to get it working in the non-Flatpaked IDE.:
curl --proto ‘=https’ --tlsv1.2 -sSf https://sh.rustup.rs | sh
Follow the instructions of the script from the previous line.
Toolchain location or wtv is the following if I recall correctly: /home/myusername/.cargo/bin
Run the following command.: rustup component add rust-src
Standard library or wtv is the following if I recall correctly: /home/myusername/.rustup/toolchains/stable-x86_64-unknown-linux-gnu/lib/rustlib/src/rust/src
Run → Edit Configurations
Environment variables: PKG_CONFIG_PATH=/var/run/host/usr/lib/x86_64-linux-gnu/pkgconfig/;PATH=/home/myusername/.rustup/toolchains/stable-x86_64-unknown-linux-gnu/lib/rustlib/x86_64-unknown-linux-gnu/bin/gcc-ld:/home/myusername/.cargo/bin:/var/run/host/usr/local/bin:/var/run/host/usr/bin:/bin:/var/run/host/usr/local/games:/var/run/host/usr/games
Working directory: /home/myusername/IdeaProjects/untitled12
Make main.rs be as follows.:
use gtk4 as gtk;
use gtk::prelude::*;
use gtk::{Application, ApplicationWindow};
fn main() {
println!("Hello, world!");
let app = Application::builder()
.application_id("org.example.HelloWorld")
.build();
app.connect_activate(|app| {
// We create the main window.
let window = ApplicationWindow::builder()
.application(app)
.default_width(320)
.default_height(200)
.title("Hello, World!")
.build();
// Show the window.
window.show();
app.run();
println!("Goodbye, world!");
- Make Cargo.toml be as follows.:
[package]
name = "untitled12"
version = "0.1.0"
edition = "2021"
# See more keys and their definitions at https://doc.rust-lang.org/cargo/reference/manifest.html
[dependencies]
gtk4 = "0.4.7"
gdk4-sys = "0.4.2"
gsk4-sys = "0.4.2"
graphene-sys = "0.15.10"
But, when I try to do it in the Flatpaked IntelliJ IDEA Community Edition IDE, I get the following error.:
error: linking with `cc` failed: exit status: 1
= note: "cc" "-m64" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/untitled10-5f1fe85ad9a91cbd.143cbefya22s2u14.rcgu.o" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/untitled10-5f1fe85ad9a91cbd.145jeavqho73qjm9.rcgu.o" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/untitled10-5f1fe85ad9a91cbd.1a06ydxfllht0hus.rcgu.o" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/untitled10-5f1fe85ad9a91cbd.1i9zx9edha2qex5x.rcgu.o" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/untitled10-5f1fe85ad9a91cbd.1w7mybzopgskabss.rcgu.o" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/untitled10-5f1fe85ad9a91cbd.1ys195vx6akv7z97.rcgu.o" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/untitled10-5f1fe85ad9a91cbd.1zcxsoy4a8e0eywn.rcgu.o" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/untitled10-5f1fe85ad9a91cbd.20cvzochebdhwd6p.rcgu.o" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/untitled10-5f1fe85ad9a91cbd.21ew2v9c0nn3zvh6.rcgu.o" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/untitled10-5f1fe85ad9a91cbd.23w9mbmfnghnscw1.rcgu.o" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/untitled10-5f1fe85ad9a91cbd.25q5o31v4mb6jxrv.rcgu.o" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/untitled10-5f1fe85ad9a91cbd.297bd778li4p2czm.rcgu.o" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/untitled10-5f1fe85ad9a91cbd.2aal6wm7z5vj8eu4.rcgu.o" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/untitled10-5f1fe85ad9a91cbd.2hzoz1daskfv966m.rcgu.o" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/untitled10-5f1fe85ad9a91cbd.2ovbhkh7sqgat8wm.rcgu.o" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/untitled10-5f1fe85ad9a91cbd.36fssa5ap3aaanwb.rcgu.o" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/untitled10-5f1fe85ad9a91cbd.38cddkmw87se7k1t.rcgu.o" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/untitled10-5f1fe85ad9a91cbd.3d0m3ymzk673jvzv.rcgu.o" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/untitled10-5f1fe85ad9a91cbd.3feurxnmpmevbsbs.rcgu.o" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/untitled10-5f1fe85ad9a91cbd.3iif71qg43oluoah.rcgu.o" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/untitled10-5f1fe85ad9a91cbd.3mccsqiauqqdqpn6.rcgu.o" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/untitled10-5f1fe85ad9a91cbd.3x30eth8ldbnklau.rcgu.o" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/untitled10-5f1fe85ad9a91cbd.40plrzzzbldtvj91.rcgu.o" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/untitled10-5f1fe85ad9a91cbd.48i1nntxua988u81.rcgu.o" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/untitled10-5f1fe85ad9a91cbd.4bflb0x6kyiaf3lk.rcgu.o" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/untitled10-5f1fe85ad9a91cbd.4elgbyo7a7muzplm.rcgu.o" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/untitled10-5f1fe85ad9a91cbd.4hhiwmc0s3beb2xo.rcgu.o" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/untitled10-5f1fe85ad9a91cbd.4rqre5f4fr53w1wy.rcgu.o" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/untitled10-5f1fe85ad9a91cbd.4tbcfm7ryux92fg6.rcgu.o" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/untitled10-5f1fe85ad9a91cbd.53d9r75b32r94lh8.rcgu.o" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/untitled10-5f1fe85ad9a91cbd.54r7u1cwhhd2cdq7.rcgu.o" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/untitled10-5f1fe85ad9a91cbd.55gev68w9hq5gax0.rcgu.o" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/untitled10-5f1fe85ad9a91cbd.59wj7oem0pk1ni57.rcgu.o" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/untitled10-5f1fe85ad9a91cbd.5m3qcvkvmfehtju.rcgu.o" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/untitled10-5f1fe85ad9a91cbd.aqnsygsb6ax17dl.rcgu.o" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/untitled10-5f1fe85ad9a91cbd.mrwapxv4ta5yy9r.rcgu.o" "-Wl,--as-needed" "-L" "/home/myusername/IdeaProjects/untitled10/target/debug/deps" "-L" "/home/myusername/.rustup/toolchains/stable-x86_64-unknown-linux-gnu/lib/rustlib/x86_64-unknown-linux-gnu/lib" "-Wl,-Bstatic" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/libgtk4-ca902c7f7eba28c6.rlib" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/libgsk4-f86fc15a1fed60f1.rlib" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/libgraphene-d3971d917bbfbf49.rlib" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/libgdk4-cf80e7127fed318c.rlib" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/libpango-04d385c4353719c1.rlib" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/libgdk_pixbuf-6f013e886d9ed80d.rlib" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/libgio-763da2eaa5fe9719.rlib" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/libfutures_io-ae8d0cc855367cbf.rlib" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/libcairo-646c5927ff279be1.rlib" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/libglib-c6f2f6866365728f.rlib" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/libfutures_executor-22921000605cf671.rlib" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/libfutures_util-ef36e67040a629ab.rlib" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/libslab-ae59c7b6e0d36368.rlib" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/libpin_project_lite-ff7ec06daf2cd9b9.rlib" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/libpin_utils-6c669315cfadfec5.rlib" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/libsmallvec-068ac8185082e6f5.rlib" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/libthiserror-b186ca3ff4e664c6.rlib" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/libfutures_channel-0fceb783f1ba6f1e.rlib" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/libfutures_task-ecde0fd8afc76364.rlib" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/libfutures_core-e4d3a2040637810a.rlib" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/libonce_cell-d4edd22523d7b9ae.rlib" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/libbitflags-f1ca410388ec357f.rlib" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/libgtk4_sys-96fa244889173473.rlib" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/libgsk4_sys-c4f8eb77d97ab30f.rlib" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/libgraphene_sys-23e65496c528a782.rlib" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/libgdk4_sys-8edf29ea7bb9aad4.rlib" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/libgdk_pixbuf_sys-cdf2ac238dd517ec.rlib" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/libpango_sys-9ccfbf95bd0d8e4a.rlib" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/libcairo_sys-6ed51310430022c6.rlib" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/libgio_sys-ad3999ab84f22338.rlib" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/libgobject_sys-440edb70b0cd853f.rlib" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/libglib_sys-156b714538c596d6.rlib" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/liblibc-c8abee9503293ab0.rlib" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/libfield_offset-34477f9ac2df78c9.rlib" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/libmemoffset-9c9e2ab89dd01fb6.rlib" "-Wl,--start-group" "/home/myusername/.rustup/toolchains/stable-x86_64-unknown-linux-gnu/lib/rustlib/x86_64-unknown-linux-gnu/lib/libstd-8d61b92a0a02f53a.rlib" "/home/myusername/.rustup/toolchains/stable-x86_64-unknown-linux-gnu/lib/rustlib/x86_64-unknown-linux-gnu/lib/libpanic_unwind-fc45202bb435016b.rlib" "/home/myusername/.rustup/toolchains/stable-x86_64-unknown-linux-gnu/lib/rustlib/x86_64-unknown-linux-gnu/lib/libminiz_oxide-f2400674c7513725.rlib" "/home/myusername/.rustup/toolchains/stable-x86_64-unknown-linux-gnu/lib/rustlib/x86_64-unknown-linux-gnu/lib/libadler-605c3a7d1a5d300d.rlib" "/home/myusername/.rustup/toolchains/stable-x86_64-unknown-linux-gnu/lib/rustlib/x86_64-unknown-linux-gnu/lib/libobject-3d4fb4efa907e4e8.rlib" "/home/myusername/.rustup/toolchains/stable-x86_64-unknown-linux-gnu/lib/rustlib/x86_64-unknown-linux-gnu/lib/libmemchr-65207f030ab23308.rlib" "/home/myusername/.rustup/toolchains/stable-x86_64-unknown-linux-gnu/lib/rustlib/x86_64-unknown-linux-gnu/lib/libaddr2line-76ca199cb0186109.rlib" "/home/myusername/.rustup/toolchains/stable-x86_64-unknown-linux-gnu/lib/rustlib/x86_64-unknown-linux-gnu/lib/libgimli-1e3e01ed4f561dc1.rlib" "/home/myusername/.rustup/toolchains/stable-x86_64-unknown-linux-gnu/lib/rustlib/x86_64-unknown-linux-gnu/lib/librustc_demangle-dd8dddcba7c13fee.rlib" "/home/myusername/.rustup/toolchains/stable-x86_64-unknown-linux-gnu/lib/rustlib/x86_64-unknown-linux-gnu/lib/libstd_detect-00b13d31c3420656.rlib" "/home/myusername/.rustup/toolchains/stable-x86_64-unknown-linux-gnu/lib/rustlib/x86_64-unknown-linux-gnu/lib/libhashbrown-e4c8460b81557bd5.rlib" "/home/myusername/.rustup/toolchains/stable-x86_64-unknown-linux-gnu/lib/rustlib/x86_64-unknown-linux-gnu/lib/librustc_std_workspace_alloc-600d46e5f0005455.rlib" "/home/myusername/.rustup/toolchains/stable-x86_64-unknown-linux-gnu/lib/rustlib/x86_64-unknown-linux-gnu/lib/libunwind-e4a08a2585b62d37.rlib" "/home/myusername/.rustup/toolchains/stable-x86_64-unknown-linux-gnu/lib/rustlib/x86_64-unknown-linux-gnu/lib/libcfg_if-fbc21ec567cb9dc7.rlib" "/home/myusername/.rustup/toolchains/stable-x86_64-unknown-linux-gnu/lib/rustlib/x86_64-unknown-linux-gnu/lib/liblibc-10b3fa8e49bd978f.rlib" "/home/myusername/.rustup/toolchains/stable-x86_64-unknown-linux-gnu/lib/rustlib/x86_64-unknown-linux-gnu/lib/liballoc-64625b73694ffce7.rlib" "/home/myusername/.rustup/toolchains/stable-x86_64-unknown-linux-gnu/lib/rustlib/x86_64-unknown-linux-gnu/lib/librustc_std_workspace_core-fb6b78ac543a58ee.rlib" "/home/myusername/.rustup/toolchains/stable-x86_64-unknown-linux-gnu/lib/rustlib/x86_64-unknown-linux-gnu/lib/libcore-1d1f2d1bec6f51b8.rlib" "-Wl,--end-group" "/home/myusername/.rustup/toolchains/stable-x86_64-unknown-linux-gnu/lib/rustlib/x86_64-unknown-linux-gnu/lib/libcompiler_builtins-acf5ff6e9595d982.rlib" "-Wl,-Bdynamic" "-lgobject-2.0" "-lgtk-4" "-lpangocairo-1.0" "-lpango-1.0" "-lharfbuzz" "-lgdk_pixbuf-2.0" "-lcairo-gobject" "-lcairo" "-lgraphene-1.0" "-lgio-2.0" "-lgobject-2.0" "-lglib-2.0" "-lgtk-4" "-lpangocairo-1.0" "-lpango-1.0" "-lharfbuzz" "-lgdk_pixbuf-2.0" "-lcairo-gobject" "-lcairo" "-lgraphene-1.0" "-lgio-2.0" "-lgobject-2.0" "-lglib-2.0" "-lgraphene-1.0" "-lgobject-2.0" "-lglib-2.0" "-lgtk-4" "-lpangocairo-1.0" "-lpango-1.0" "-lharfbuzz" "-lgdk_pixbuf-2.0" "-lcairo-gobject" "-lcairo" "-lgraphene-1.0" "-lgio-2.0" "-lgobject-2.0" "-lglib-2.0" "-lgdk_pixbuf-2.0" "-lgobject-2.0" "-lglib-2.0" "-lpango-1.0" "-lgobject-2.0" "-lglib-2.0" "-lharfbuzz" "-lcairo-gobject" "-lcairo" "-lgobject-2.0" "-lglib-2.0" "-lgio-2.0" "-lgobject-2.0" "-lglib-2.0" "-lgobject-2.0" "-lglib-2.0" "-lgobject-2.0" "-lglib-2.0" "-lgcc_s" "-lutil" "-lrt" "-lpthread" "-lm" "-ldl" "-lc" "-Wl,--eh-frame-hdr" "-Wl,-znoexecstack" "-L" "/home/myusername/.rustup/toolchains/stable-x86_64-unknown-linux-gnu/lib/rustlib/x86_64-unknown-linux-gnu/lib" "-o" "/home/myusername/IdeaProjects/untitled10/target/debug/deps/untitled10-5f1fe85ad9a91cbd" "-Wl,--gc-sections" "-pie" "-Wl,-zrelro,-znow" "-nodefaultlibs"
= note: /usr/lib/gcc/x86_64-unknown-linux-gnu/11.3.0/../../../../x86_64-unknown-linux-gnu/bin/ld: cannot find -lgtk-4
/usr/lib/gcc/x86_64-unknown-linux-gnu/11.3.0/../../../../x86_64-unknown-linux-gnu/bin/ld: cannot find -lgraphene-1.0
collect2: error: ld returned 1 exit status
I even tried to make a /home/myusername/.cargo/config.toml file with the following contents (but I’m very confused with rustflags stuff).:
rustflags = ["-L", "/home/myusername/.rustup/toolchains/stable-x86_64-unknown-linux-gnu/lib/rustlib/x86_64-unknown-linux-gnu/bin/gcc-ld"]
By the way, here are the sandboxing details (which is kind of a mess because I’ve tried many different things, all of which failed, before posting here).:
root@debian:~# flatpak override --show
[Context]
filesystems=/var/lib/flatpak/runtime/org.gnome.Sdk/x86_64/42/bd5cf2646c70337561c1a2bf214e3ca797fd2ea96d981baf8fd537cb931eeebb/files/lib/x86_64-linux-gnu;/var/lib/flatpak/runtime/org.gnome.Sdk/x86_64/42/bd5cf2646c70337561c1a2bf214e3ca797fd2ea96d981baf8fd537cb931eeebb/files/x86_64-unknown-linux-gnu/bin;/var/lib/flatpak/runtime/org.gnome.Sdk;/var/lib/flatpak/runtime/org.gnome.Sdk/x86_64/42/active/files/sbin;/var;/usr/lib/x86_64-linux-gnu/pkgconfig;/var/lib/flatpak/runtime/org.kde.Platform/x86_64/5.15/2c9e014e7d60da0f002c9d9d7a620bcedf59546007a7ae16accb3ee3e6335430/files/lib/x86_64-linux-gnu;/var/lib/flatpak/runtime/org.gnome.Sdk/x86_64/42/bd5cf2646c70337561c1a2bf214e3ca797fd2ea96d981baf8fd537cb931eeebb/files/bin;host;/home/guest;
root@debian:~# flatpak override --show com.jetbrains.IntelliJ-IDEA-Community
[Context]
filesystems=/var/lib/flatpak/runtime/org.gnome.Sdk/x86_64/42/bd5cf2646c70337561c1a2bf214e3ca797fd2ea96d981baf8fd537cb931eeebb/files/x86_64-unknown-linux-gnu/bin;/usr/share/cargo/registry/graphene-sys-0.14.8;/var/lib/flatpak/runtime:ro;/usr/share/cargo/registry/gdk4-sys-0.3.1:ro;/home/myusername/IdeaProjects;/var/lib/flatpak/runtime/org.kde.Platform/x86_64/5.15/2c9e014e7d60da0f002c9d9d7a620bcedf59546007a7ae16accb3ee3e6335430/files/lib/x86_64-linux-gnu;/var;/var/lib/flatpak/runtime/org.gnome.Sdk/x86_64/42/bd5cf2646c70337561c1a2bf214e3ca797fd2ea96d981baf8fd537cb931eeebb/files/lib/x86_64-linux-gnu/pkgconfig;/home/guest;/usr/lib/x86_64-linux-gnu/gtk-4.0/4.0.0:ro;/var/lib/flatpak/runtime/org.gnome.Sdk;/usr/share/cargo/registry/gsk4-sys-0.3.1:ro;/var/lib/flatpak/runtime/org.gnome.Sdk/x86_64/42/bd5cf2646c70337561c1a2bf214e3ca797fd2ea96d981baf8fd537cb931eeebb/files/bin;host;/home/myusername;/usr/lib/x86_64-linux-gnu/graphene-1.0:ro;/home/myusername/.cargo;/usr/lib/x86_64-linux-gnu/pkgconfig;/usr/include/graphene-1.0;/var/lib/flatpak/runtime/org.gnome.Sdk/x86_64/42/active/files/sbin;/var/lib/flatpak/runtime/org.gnome.Sdk/x86_64/42/bd5cf2646c70337561c1a2bf214e3ca797fd2ea96d981baf8fd537cb931eeebb/files/lib/x86_64-linux-gnu;
root@debian:~#
Ideally, I’d like to use everything, including the Rust and GNOME runtimes, from Flatpak and Flathub, but I can accept using the IDE as a Flatpak with Rustup from upstream and with GNOME and GTK-related stuff being from the Debian repositories or upstream. (I don’t think Rust stuff in the Debian (stable) repositories would be new enough for my needs. For example, right now, Gtk 4 requires Rust to be at version 1.56.0 or newer, but the Debian repository’s rustc package is currently at version 1.48.0.)
I’m trying to avoid upstream’s IntelliJ, one reason being that I’d like to upgrade my whole system in one shot, but if I can’t figure out how to do it, I guess I can sandbox the upstream version with Firejail and use that.
So, could someone please help me with what I am trying to achieve?
Any input would be GREATLY appreciated!
