An application of mine requires a DBus service to communicate with a GNOME Shell extension. Can I package such an application with Flatpak?
I tried installing the service in the Flatpak file system. This triggered the following error:
Running: install -Dm644 -t /usr/share/dbus-1/services/ meta/io.github.pieterdd.StretchBreak.Core.service
install: cannot create regular file ‘/usr/share/dbus-1/services/io.github.pieterdd.StretchBreak.Core.service’: Read-only file system
The prefix /usr
is reserved for the runtime. As an application you cant put files there.
The prefix for applications is /app
. So you need to place the DBus file under /app/share/dbus-1/services
Also, if you want your app to talk to talk to a bus outside of the sandbox, you need to add the --talk-name
or --own-name
permission for the bus in question.
The service file got installed, but I don’t have the impression that it’s working completely.
The main reason I want the service file is to ensure my application can autostart when a DBus call to it is done by an accompanying GNOME Shell extension. The extension runs outside the Flatpak container. The service doesn’t seem to autostart.
Am I missing something here?
Nevermind, just needed to adapt the Exec
attribute in the service definition to reflect the new path!
