Flatpak KMyMoney - mime type is missing
Project information:
Homepage:
License:
Upstream has been contacted:
I just installed KMyMonet 5.2.1 from the flatpak store (LMDE 7.0 Gigi). Application runs fine, but the MIME type configuration appears to have been overlooked by the package manager : from the file manager (nemo) “.kmy” files are open with the archive manager program and the icon looks like an archive file. I dig a little, and there is no kmymoney mime type file in “/var/lib/flatpak/exports/share/mime/packages”, nor in “/var/lib/flatpak/app/org.kde.kmymoney/current/active/export/share/mime/org.kde.kmymoney.xml”.
I think it should be easy to correct this oversight.
This would be best reported to the developers of KMyMoney:
