Hi there.
I’m about to build a flatpak for dusklight, a zelda twilight princess port for PC. I already am at a point where is builds, with metadata, for local builds. The problem is that it requires networking at build time to pull in a precompiled googles-dawn.
I honestly don’t know how to deal with it. It doesn’t seem that there is a prebuild flatpak of dawn, and self build is out of the question, since this is a HUGE project that will probably need days to build on my hardware.
My current source is (metainfo commented out, because not required here). Now this works, locally.
app-id: dev.twilitrealm.dusklight
runtime-version: "25.08"
sdk-extensions:
- org.freedesktop.Sdk.Extension.llvm22
command: dusklight
# Graphical output
- --socket=wayland
- --socket=fallback-x11
# Audio Support
- --socket=pulseaudio
- --filesystem=xdg-run/pipewire-0
# GPU Support
- --device=dri
# Read ISO from downloads
- --filesystem=xdg-download:ro
# Controller Support
- --device=input
- name: org.libsdl.SDL3
buildsystem: cmake
build-options:
cflags: "-O3"
cxxflags: "-O3"
prepend-path: /usr/lib/sdk/llvm22/bin
env:
CC: clang
CXX: clang++
- type: archive
url: https://libsdl.org/release/SDL3-3.4.8.tar.gz
sha256: e9fff7467fb60f037e6708da18b25560649e4c63edc2a69bb871b960d9cbfbba
- name: dusklight
build-options:
build-args:
# Network access at buildtime
- --share=network
cflags: "-O3"
cxxflags: "-O3"
env:
CC: clang
CXX: clang++
- cmake -S . -B build -DDUSK_ENABLE_UPDATE_CHECKER=OFF -DCMAKE_BUILD_TYPE=RelWithDebInfo -DSDL3_DIR=/app -DCMAKE_INSTALL_PREFIX=/app
- cmake --build build -- -j$(nproc)
- cmake --install build --prefix /app
post-install:
# Correct the binary path
## Dusklight needs to run from /app, but flatpak wants it to be in /app/bin.
## Create a little helper to do this, while keeping the working directory in /app
- mkdir -p /app/bin
- printf '%s\n' '#!/usr/bin/env sh' 'cd /app' 'exec /app/dusklight "$@"' > /app/bin/dusklight
- chmod +x /app/bin/dusklight
# Install Desktop file
- install -Dm644 platforms/freedesktop/dusklight.desktop /app/share/applications/dev.twilitrealm.dusklight.desktop
## Fix up icon naming
- sed -i 's/Icon=dusklight/Icon=dev.twilitrealm.dusklight/' /app/share/applications/dev.twilitrealm.dusklight.desktop
# Install Icons
- install -Dm644 platforms/freedesktop/16x16/apps/dusklight.png /app/share/icons/hicolor/16x16/apps/dev.twilitrealm.dusklight.png
- install -Dm644 platforms/freedesktop/32x32/apps/dusklight.png /app/share/icons/hicolor/32x32/apps/dev.twilitrealm.dusklight.png
- install -Dm644 platforms/freedesktop/48x48/apps/dusklight.png /app/share/icons/hicolor/48x48/apps/dev.twilitrealm.dusklight.png
- install -Dm644 platforms/freedesktop/64x64/apps/dusklight.png /app/share/icons/hicolor/64x64/apps/dev.twilitrealm.dusklight.png
- install -Dm644 platforms/freedesktop/128x128/apps/dusklight.png /app/share/icons/hicolor/128x128/apps/dev.twilitrealm.dusklight.png
- install -Dm644 platforms/freedesktop/256x256/apps/dusklight.png /app/share/icons/hicolor/256x256/apps/dev.twilitrealm.dusklight.png
- install -Dm644 platforms/freedesktop/512x512/apps/dusklight.png /app/share/icons/hicolor/512x512/apps/dev.twilitrealm.dusklight.png
# Install metainfo
##- install -Dm644 dev.twilitrealm.dusklight.metainfo.xml /app/share/metainfo/dev.twilitrealm.dusklight.metainfo.xml
- type: git
url: https://github.com/TwilitRealm/dusklight.git
tag: v1.1.1
commit: 7a77d48954847330a5ab55f5c7f2e64cdd25d846
disable-shallow-clone: true
# - type: file
# path: dev.twilitrealm.dusklight.metainfo.xml
# dest: .
But the moment I take away
build-args:
- --share=network
It fails at:
-- aurora: Fetching prebuilt Dawn package from https://github.com/encounter/dawn-build/releases/download/v20260423.175430/dawn-linux-x86_64.tar.gz
--- LOG END ---
error: downloading 'https://github.com/encounter/dawn-build/releases/download/v20260423.175430/dawn-linux-x86_64.tar.gz' failed
status_code: 6
status_string: "Could not resolve hostname"
log:
--- LOG BEGIN ---
Could not resolve host: github.com
shutting down connection #0
That is completely expected ![]()
As I said, I can’t think of anything the workaround this.
