After an upgrade (from Fedora Kinoite 43 to 44, LibreOffice flatpak launch failed. Some thrashing about revealed that the command line needed adjustment.
Failed to open display
/app/libreoffice/program/soffice.bin X11 error: Can’t open display:
Set DISPLAY environment variable, use -display option
or check permissions of your X-Server
(See “man X” resp. “man xhost” for details)
Successful command line:
flatpak run --branch=stable --arch=x86_64 --command=libreoffice --file-forwarding org.libreoffice.LibreOffice --calc --display
Additional comment: I see no purpose in including --file-forwarding in a GUI launcher’s command line.
Cheers!
S
Sibelman
#2
Note: after a while, my “fix” stopped working in a new way: the app froze at the splash screen. Reboot seems to have cleared that, but I’m feeling gun-shy now, and resorting to using a snap install instead. I’m sure hoping someone knowledgeable can shed some light on this, as I know nothing about creating flatpaks (or snaps).
I don’t think your issue is related to the command line. --file-forwarding allows file/URI arguments to be forwarded to the app via the document portal. With the LibreOffice flatpak’s broad file access (--filesystem=host), it isn’t needed, but this is a builtin feature that can’t be turned off, and it doesn’t do any harm anyway.
As per the Desktop Entry spec, the %U specifier must be removed by the launcher if the app is launched without any URIs, so the actual resulting command line would look like this:
flatpak run --branch=stable --arch=x86_64 --command=libreoffice --file-forwarding org.libreoffice.LibreOffice --calc @@u @@
With --file-forwarding, flatpak consumes the @@u and @@, and forwards any URIs between them (none in this case). Inside the sandbox, the LibreOffice binary would only receive --calc.
As a result, flatpak run org.libreoffice.LibreOffice --calc would be practically equivalent to launching LibreOffice Calc from your desktop shell.
Are you using a Wayland or X11 session? It shouldn’t be trying to use X11 if you’re on Wayland, and by default would be unable to do so.
S
Sibelman
#5
I’m running Wayland, KDE Plasma 6.6.4, Kernel 7.0.4-200.fc44x86_64.
The only way I found to launch LibreOffice (from Plasma or bash in konsole) was to modify the command line that was furnished by the flatpak installation, adding --display :0 and removing %U. Even with those “fixes” it is still hit or miss, which at first seemed sufficient. The issue is still a complete mystery to me.
I will post something about this in the flatpak LibreOffice bugtracker area as @Erick555 seems to suggest. I’ve also mentioned it in a Fedora forum.
Yes, I’m quite ignorant. I rarely save files to the desktop, but it’s a common practice, certainement.
Thank you for your implied suggestion of additional testing. The launch command line arguments in the Plasma application launcher are used when the user double-clicks a desktop file, or launches the application from Dolphin. That explains why --file-forwarding is important.
All this does nothing (at least for me) toward explaining why the adding –display :0usually allows launching from the application launcher, but still sometimes hangs at the splash screen with an X11 icon on the command line.
My remark about --file-forwarding came from my ignorance, which is now reduced. But I also still “have no idea” about the main subject of my posting. Maybe the flatpak command line arguments are not the true source of the problem, but adding --display :0 seems to make a difference.
