One of my apps requires libprotobuf-dev
to build, but my attempt to build this lib from source with cmake
fails with error:
Failed to clone repository: 'https://github.com/google/googletest.git'
make[2]: *** [CMakeFiles/googletest-populate.dir/build.make:102: googletest-populate-prefix/src/googletest-populate-stamp/googletest-populate-download] Error 1
make[1]: *** [CMakeFiles/Makefile2:87: CMakeFiles/googletest-populate.dir/all] Error 2
make: *** [Makefile:91: all] Error 2
CMake Error at /usr/share/cmake-3.31/Modules/FetchContent.cmake:1918 (message):
Build step for googletest failed: 2
Call Stack (most recent call first):
/usr/share/cmake-3.31/Modules/FetchContent.cmake:1609 (__FetchContent_populateSubbuild)
/usr/share/cmake-3.31/Modules/FetchContent.cmake:2145:EVAL:2 (__FetchContent_doPopulation)
/usr/share/cmake-3.31/Modules/FetchContent.cmake:2145 (cmake_language)
/usr/share/cmake-3.31/Modules/FetchContent.cmake:2384 (__FetchContent_Populate)
cmake/gtest.cmake:19 (FetchContent_MakeAvailable)
CMakeLists.txt:270 (include)
-- Configuring incomplete, errors occurred!
Maybe someone can share an example of a manifest that uses this dependency in the following environment:
"runtime": "org.kde.Platform",
"sdk": "org.kde.Sdk",
"runtime-version": "5.15-24.08",
Not sure, maybe I can also install it somewhere from the runtime as the option…
Thanks!
