Sauerbrauten freezes
Hi I installed Sauerbrauten and it freezes on startup, it also freezes Gnome shell.
I need to escape to command line and reboot my Linux.
I may have changed the settings for Sauerbrauten using Flatseal and so this may be my mistake.
But I do not know what the correct settings for Sauerbrauten would be. How would I be able to find this out?
Also, it may not be the settings in Flatseal - what else could I do to prevent Sauerbrauten from freezing?
Thanks ahead of time…
You are probably better off contacting the maintainers of this app.
If you want to undo the flatpak overrides, you could try flatpak override --reset <app-id>
Thanks for the help :slight_smile:
I will try your suggestions…
