[Solved for now] Either "HTTP 404" or "exceeded maximum size"
Hi Everyone,
I am kindly asking for support on Trying to install gives a 404 · Issue #56 · flathub/app.organicmaps.desktop · GitHub.
Essentially when trying to install the flatpak there are two scenarios which alternating:
1: HTTP 404
Error: While pulling app/app.organicmaps.desktop/x86_64/stable from remote flathub: Server returned HTTP 404
error: Failed to install app.organicmaps.desktop: While pulling app/app.organicmaps.desktop/x86_64/stable from remote flathub: Server returned HTTP 404
2: exceeded maximum size:
Error: While pulling app/app.organicmaps.desktop/x86_64/stable from remote flathub: URI https://dl.flathub.org/repo/deltas/I5/yQw3_uGE1JXjXR+W30RVEiTVUxLODGZBt4jDz6Xyw/5 exceeded maximum size of 4302889 bytes
error: Failed to install app.organicmaps.desktop: While pulling app/app.organicmaps.desktop/x86_64/stable from remote flathub: URI https://dl.flathub.org/repo/deltas/I5/yQw3_uGE1JXjXR+W30RVEiTVUxLODGZBt4jDz6Xyw/5 exceeded maximum size of 4302889 bytes
Your help is much appreciated.
Publishing a new rebuild has not helped either.
After publishing with an actual change now it works again… Odd.
