Ul and li not authorized despite documentation says it
Apr 19, 2026 Closed
B
I am packaging my first application here. I am confused about the use of
    and
  • tags in the description and release fields of the metainfo.xml
    According to flathub documentation, it is the right way to put up a description list . See MetaInfo guidelines | Flathub Documentation
    However, when I run the linter (also recommended in the documentation), the ul and li tags are reported as errors.
    What’s the source of truth ? If I don’t use
  • tags, what’s the proper way to provide a feature list ?
B
Ok, I figured it out.
html-like nested tags don’t work like :
<p> A list :
  <ul>
     <li>A list item</li>
  </ul>
</p>
But
    as main tag will work :
    <p>A list:</p>
    <ul>
      <li>An item</li>
    </ul>
