Project information:
Homepage: https://xmake.io
License: Apache 2.0
Upstream has been contacted:
I want to build my flatpak app using this build system, which I have installed in my Fedora linux workstation. It works fine, but trying to use it with flatpak-builder fails, because the xmake command cannot be found. My manifest file:
runtime-version: '23.08'
command: app1_linux_x86_64-release
- name: App1
# The install prefix must be /app
- xmake build app1
- xmake install -o ./app app1
# builddir: true
- type: dir
path: /home/paul/Programming/xmake/X/
# Wayland access
- --socket=wayland
# Show windows using X11, if Wayland is not available,
# overrides x11 socket permission
- --socket=fallback-x11
# share IPC namespace with the host (necessary for X11)
- --share=ipc
# OpenGL rendering
- --device=dri
# Audio
- --socket=pulseaudio
cleanup:
- xmake f -c
I’ve tried to write the build commands into a shell script file and calling that file in the build-commands section, but it also cannot find the xmake executable
