I installed the Flatpak to use Kdenlive on my Puppy linux 9.5.
The Flatpak was installed by Puppy Package Manager.
I got an installation file from the Flathub that was named “org.kde.kdenlive.flatpakref”.
I typed in my download directory.
flatpak install org.kde.kdenlive.flatpakref
Some files were downloaded and it looked like installing. I got a error message when I type
flatpak run org.kde.kdenlive.
ERROR: ld.so: object ‘/usr/lib/x86_64-linux-gnu/libgtk3-nocsd.so.0’ from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
kf.dbusaddons: DBus session bus not found. To circumvent this problem try the following command (with bash):
- export $(dbus-launch)*
I typed same as “export $(dbus-launch)” and Kdenlive could be launched. I looked this message and found that it could be solved with installation of gtk3-nocsd_3 but it was installed already by Puppy package manager.
First, I do not want to see this error.
Even it was launched but I could not use because there were another error messages.
In the Kdenlive, it said
Error - Kdenlive
Could not create the video preview window. There is something wrong with your Kdenlive install or your driver setting, please fix it.
I need help about it.
Thanks in further.
