Appstream problem while building
hello everyone
i have an app when i build it locally it runs but when i build it using flathub building bot in github it fails and i find in the logs:
appstream-missing-appinfo-file
i have a manifest, metainfo, desktop, and an icon file
here is the repo GitHub - Sera-L/org.supertuxproject.SuperTux · GitHub
and here is the pr build org.supertuxproject.SuperTux/test from refs/pull/32/head · flathub-infra/vorarbeiter@d3a1b90 · GitHub
You’re getting lot of G_IO_ERROR_NOT_FOUND errors in the Validate build task, seems it cannot find the paths.
I don’t know the project, I see in the manifest: rename-desktop-file, rename-appdata-file, buildsystem: cmake-ninja, build-commands with install with paths, config-opts with install paths.
Maybe you can check the paths…
Someone expert on the build platform can answer you soon.
bye
i see just a one error and it is appstream-missing-appinfo-file
Above the error:
`2026-03-19 15:38:02,161 DEBUG:flatpak_builder_lint.ostree:extract_subpath: Checking out subpath files/share/app-info with G_IO_ERROR_NOT_FOUND allowed for ref app/org.supertuxproject.SuperTux/x86_64/test at dest /work/tmp/tmpokpfirmo/app-info` `2026-03-19 15:38:02,162 DEBUG:flatpak_builder_lint.ostree:extract_subpath: Checking out subpath files/share/applications with G_IO_ERROR_NOT_FOUND allowed for ref app/org.supertuxproject.SuperTux/x86_64/test at dest /work/tmp/tmpokpfirmo/applications` `2026-03-19 15:38:02,162 DEBUG:flatpak_builder_lint.ostree:extract_subpath: Checking out subpath files/share/icons with G_IO_ERROR_NOT_FOUND allowed for ref app/org.supertuxproject.SuperTux/x86_64/test at dest /work/tmp/tmpokpfirmo/icons` `2026-03-19 15:38:02,163 DEBUG:flatpak_builder_lint.ostree:extract_subpath: Checking out subpath files/share/app-info with G_IO_ERROR_NOT_FOUND allowed for ref app/org.supertuxproject.SuperTux/x86_64/test at dest /work/tmp/tmpert89q4p/app-info` `2026-03-19 15:38:02,164 DEBUG:flatpak_builder_lint.ostree:extract_subpath: Checking out subpath files/share/applications with G_IO_ERROR_NOT_FOUND allowed for ref app/org.supertuxproject.SuperTux/x86_64/test at dest /work/tmp/tmpert89q4p/applications` `2026-03-19 15:38:02,164 DEBUG:flatpak_builder_lint.ostree:extract_subpath: Checking out subpath files/share/icons with G_IO_ERROR_NOT_FOUND allowed for ref app/org.supertuxproject.SuperTux/x86_64/test at dest /work/tmp/tmpert89q4p/icons` `2026-03-19 15:38:02,166 DEBUG:flatpak_builder_lint.ostree:extract_subpath: Checking out subpath /metadata for ref app/org.supertuxproject.SuperTux/x86_64/test at dest /work/tmp/tmprk1dk9xh` `2026-03-19 15:38:02,167 DEBUG:flatpak_builder_lint.ostree:extract_subpath: Checking out subpath /metadata for ref app/org.supertuxproject.SuperTux/x86_64/test at dest /work/tmp/tmp3_6fxfvm` `2026-03-19 15:38:02,168 DEBUG:flatpak_builder_lint.ostree:extract_subpath: Checking out subpath /metadata for ref app/org.supertuxproject.SuperTux/x86_64/test at dest /work/tmp/tmpe59x900f` `2026-03-19 15:38:02,168 DEBUG:flatpak_builder_lint.ostree:extract_subpath: Checking out subpath /files/flathub.json with G_IO_ERROR_NOT_FOUND allowed for ref app/org.supertuxproject.SuperTux/x86_64/test at dest /work/tmp/tmpe59x900f` `2026-03-19 15:38:02,169 DEBUG:flatpak_builder_lint.ostree:extract_subpath: Checking out subpath files/share/appdata with G_IO_ERROR_NOT_FOUND allowed for ref app/org.supertuxproject.SuperTux/x86_64/test at dest /work/tmp/tmpgg0tdpi8/appdata` `2026-03-19 15:38:02,169 DEBUG:flatpak_builder_lint.ostree:extract_subpath: Checking out subpath files/share/metainfo with G_IO_ERROR_NOT_FOUND allowed for ref app/org.supertuxproject.SuperTux/x86_64/test at dest /work/tmp/tmpgg0tdpi8/metainfo` `2026-03-19 15:38:02,217 DEBUG:flatpak_builder_lint.checks.reposize:get_dir_size: Directory size for repo: 675736424 bytes` `2026-03-19 15:38:02,218 DEBUG:flatpak_builder_lint.ostree:extract_subpath: Checking out subpath files/share/appdata with G_IO_ERROR_NOT_FOUND allowed for ref app/org.supertuxproject.SuperTux/x86_64/test at dest /work/tmp/tmp95yrgb2r/appdata` `2026-03-19 15:38:02,218 DEBUG:flatpak_builder_lint.ostree:extract_subpath: Checking out subpath files/share/metainfo with G_IO_ERROR_NOT_FOUND allowed for ref app/org.supertuxproject.SuperTux/x86_64/test at dest /work/tmp/tmp95yrgb2r/metainfo` `2026-03-19 15:38:02,219 DEBUG:flatpak_builder_lint.ostree:extract_subpath: Checking out subpath files/share/app-info with G_IO_ERROR_NOT_FOUND allowed for ref app/org.supertuxproject.SuperTux/x86_64/test at dest /work/tmp/tmp95yrgb2r/app-info` `2026-03-19 15:38:02,238 DEBUG:flatpak_builder_lint.domainutils:get_remote_exceptions_github: Request headers for ``https://raw.githubusercontent.com/flathub-infra/flatpak-builder-lint/HEAD/flatpak_builder_lint/staticfiles/exceptions.json:`` {‘User-Agent’: ‘python-requests/2.32.5’, ‘Accept-Encoding’: ‘gzip, deflate’, ‘Accept’: ‘`*`/`*`’, ‘Connection’: ‘keep-alive’}` `2026-03-19 15:38:02,238 DEBUG:flatpak_builder_lint.domainutils:get_remote_exceptions_github: Response headers for ``https://raw.githubusercontent.com/flathub-infra/flatpak-builder-lint/HEAD/flatpak_builder_lint/staticfiles/exceptions.json:`` {‘Connection’: ‘keep-alive’, ‘Content-Length’: ‘41010’, ‘Cache-Control’: ‘max-age=300’, ‘Content-Security-Policy’: “default-src ‘none’; style-src ‘unsafe-inline’; sandbox”, ‘Content-Type’: ‘text/plain; charset=utf-8’, ‘ETag’: ‘W/“d5786228ffc32afd765904e513b45760db81c6f527add0396f056ad15addc173”’, ‘Strict-Transport-Security’: ‘max-age=31536000’, ‘X-Content-Type-Options’: ‘nosniff’, ‘X-Frame-Options’: ‘deny’, ‘X-XSS-Protection’: ‘1; mode=block’, ‘X-GitHub-Request-Id’: ‘D1D0:1259D7:E352DD:1009AEC:69BB91DB’, ‘Content-Encoding’: ‘gzip’, ‘Accept-Ranges’: ‘bytes’, ‘Date’: ‘Thu, 19 Mar 2026 15:38:02 GMT’, ‘Via’: ‘1.1 varnish’, ‘X-Served-By’: ‘cache-iad-kjyo7100071-IAD’, ‘X-Cache’: ‘HIT’, ‘X-Cache-Hits’: ‘0’, ‘X-Timer’: ‘S1773934682.234124,VS0,VE2’, ‘Vary’: ‘Authorization,Accept-Encoding’, ‘Access-Control-Allow-Origin’: ‘*’, ‘Cross-Origin-Resource-Policy’: ‘cross-origin’, ‘X-Fastly-Request-ID’: ‘6e20a4dbe5d8d968cb06c7c443c8d8a9f8c73e16’, ‘Expires’: ‘Thu, 19 Mar 2026 15:43:02 GMT’, ‘Source-Age’: ‘267’}` `2026-03-19 15:38:02,240 DEBUG:flatpak_builder_lint.domainutils:get_remote_exceptions_github: Loaded remote exceptions for org.supertuxproject.SuperTux (repo key: stable) from ``https://raw.githubusercontent.com/flathub-infra/flatpak-builder-lint/HEAD/flatpak_builder_lint/staticfiles/exceptions.json:`` set()` `2026-03-19 15:38:02,241 DEBUG:flatpak_builder_lint.cli:run_checks: Using remote exceptions: set()` `2026-03-19 15:38:02,243 DEBUG:flatpak_builder_lint.cli:get_local_exceptions: Loaded local exceptions for org.supertuxproject.SuperTux (repo key: stable): set()` `2026-03-19 15:38:02,243 DEBUG:flatpak_builder_lint.cli:run_checks: Falling back to local exceptions: set()` `Error: ‘appstream-missing-appinfo-file’ error found in linter repo check. Details: Appstream catalogue file is missing. Perhaps no Metainfo file was installed with correct name`
I don’t know, it seems a trouble with paths.
I edited your post to hide the code lines. Make sure to use code blocks inside a para to paste a large block of code, not inline.
It means you aren’t installing the metainfo file in the correct place or it is being installed with the wrong filename. The filename needs to be $FLATPAK_ID.metainfo.xml and the install location should be $FLATPAK_DEST/share/metainfo which resolves to /app/share/metainfo for an app.
In this case your install command is wrong, it has ${FLATPAK_DEST}/app which is /app/app and makes no sense.
- install -Dm644 org.supertuxproject.SuperTux.metainfo.xml ${FLATPAK_DEST}/app/share/metainfo/org.supertuxproject.SuperTux.metainfo.xml
