Hello there!
I’m having a particular issue. I’m creating my first flatpack and it is for a java-based application. How it works is that it has a stable version on the internet and when you start it, it creates a folder null in the current directory which it then just overwrites some libs, updating it next time it is ran.
For now I put the application and it’s lib folder under /app/share/<appname>. Now, I am getting an error that my system is Read-Only, I don’t know whether this is because I’m running silverblue or by design.
Is there a way for me to actually allow for the app to auto-update itself? Otherwise it’s going to say it has to update every single time or I have to manually check constantly for an update.
Here are my files. I’m open for any constructive criticism!
app-id: com.mmoui.Minion
runtime-version: '22.08'
command: minion.sh
- name: java8-runtime
- mkdir -p /app/java/
- cp -r jre /app/java/
- type: archive
url: https://cdn.azul.com/zulu/bin/zulu8.66.0.15-ca-fx-jdk8.0.352-linux_x64.tar.gz
sha256: 5e18c7fb108a14e5cba70354908d3ded7e7e741554fb7ddc5f8d9d297f8c9307
- name: minion-client
- unzip Minion3.0.5-java.zip
- mkdir -p /app/share/minion/lib
- install -Dm755 -v lib/* -t /app/share/minion/lib
- install -Dm755 -v Minion-jfx.jar /app/share/minion
- type: file
url: https://cdn.mmoui.com/minion/v3/Minion3.0.5-java.zip
sha256: 0098613cce6e3b99decc45e6ecf6b71c4b8eed7fe0cd991611d6df5a7093bc1b
- name: minion
- install -D minion.sh /app/bin/minion.sh
- type: file
path: minion.sh
cleanup:
- /app/share/minion
- --env=PATH=/app/java/jre/bin:/usr/bin:/app/bin
- --share=ipc
- --socket=x11
- --socket=wayland
- --socket=fallback-x11
- --share=network
- --device=dri
- --filesystem=host
- --filesystem=~/.var/app/com.valvesoftware.Steam
#!/bin/bash
# Couldn't enable autoupdate, this way it at least doesn't make a file in working dir
cd /app/share/minion/
java -jar /app/share/minion/Minion-jfx.jar```
