I’m updating a Flatpak so it’ll run on Gnome platform 41. C++ has been updated, to the point that several modules from other sources which it depends on, which were written for much older versions fail. I have managed to fix most of them, however I couldn’t get Vigra to compile and it hasn’t had any work done on it for years.
- name: vigra
buildsystem: cmake
config-opts:
- -DWITH_OPENEXR=ON
- type: archive
path: /home/chris/vigra-1.11.1.tar.gz
cleanup:
- /bin
- /doc
- /lib/vigra/
- /share
Fedora has patched it and I created the patched version by doing this (from Ask Fedora):
sudo dnf -y install fedpkg
fedpkg clone --anonymous vigra
cd vigra
fedpkg prep
That creates a vigra-1.11.1 sub-directory which has all of the Fedora patches applied. Unfortunately that fails too. I am not a C++ programmer so I’m stuck now.
Building module vigra in /home/chris/.flatpak-builder/build/vigra-13
CMake Warning (dev) in CMakeLists.txt:
No project() command is present. The top-level CMakeLists.txt file must
contain a literal, direct call to the project() command. Add a line of
code such as
project(ProjectName)
near the top of the file, but after cmake_minimum_required().
CMake is pretending there is a "project(Project)" command on the first
line.
This warning is for project developers. Use -Wno-dev to suppress it.
-- The C compiler identification is GNU 11.2.0
-- The CXX compiler identification is GNU 11.2.0
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: /usr/bin/cc - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++ - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
No cmake_minimum_required command is present. A line of code such as
cmake_minimum_required(VERSION 3.21)
should be added at the top of the file. The version specified may be lower
if you wish to support older CMake versions for this project. For more
information run "cmake --help-policy CMP0000".
-- Configuring done
CMake Warning (dev) at examples/tutorial/CMakeLists.txt:23 (ADD_EXECUTABLE):
Policy CMP0115 is not set: Source file extensions must be explicit. Run
"cmake --help-policy CMP0115" for policy details. Use the cmake_policy
command to set the policy and suppress this warning.
File:
/run/build/vigra/examples/tutorial/graph_agglomerative_clustering.cxx
File:
/run/build/vigra/examples/tutorial/smooth_blockwise.cxx
-- Generating done
CMake Warning:
Manually-specified variables were not used by the project:
WITH_OPENEXR
-- Build files have been written to: /run/build/vigra
[1/22] Building CXX object impex/CMakeFiles/vigraimpex.dir/bmp.o
FAILED: impex/CMakeFiles/vigraimpex.dir/bmp.o
/usr/bin/c++ -O2 -g -pipe -Wp,-D_FORTIFY_SOURCE=2 -Wp,-D_GLIBCXX_ASSERTIONS -fexceptions -fstack-protector-strong -grecord-gcc-switches -fasynchronous-unwind-tables -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer -MD -MT impex/CMakeFiles/vigraimpex.dir/bmp.o -MF impex/CMakeFiles/vigraimpex.dir/bmp.o.d -o impex/CMakeFiles/vigraimpex.dir/bmp.o -c /run/build/vigra/impex/bmp.cxx
/run/build/vigra/impex/bmp.cxx:38:10: fatal error: vigra/config.hxx: No such file or directory
38 | #include "vigra/config.hxx"
compilation terminated.
ninja: build stopped: subcommand failed.
Error: module vigra: Child process exited with code 1
