Cam someone help with error 56
Hi when it try to install an app on flatpak it always comes back to me error 56 failled and I haven’t been able to fix it, I also don’t think its my network because it works on my other pc.
what it gave me:
flatpak install discord
Looking for matches…
Similar refs found for ‘discord’ in remote ‘flathub’ (system):
   1) app/de.shorsh.discord-screenaudio/x86_64/stable
   2) app/com.discordapp.Discord/x86_64/stable
Which do you want to use (0 to abort)? [0-2]: 2
Required runtime for com.discordapp.Discord/x86_64/stable (runtime/org.freedesktop.Platform/x86_64/24.08) found in remote flathub
Do you want to install it? [Y/n]:
com.discordapp.Discord permissions:
    ipc                             network          pcsc                    pulseaudio
    x11                             devices          file access [1]         dbus access [2]
    system dbus access [3]          tags [4]
    [1] xdg-download, xdg-pictures:ro, xdg-run/speech-dispatcher, xdg-videos:ro
    [2] com.canonical.AppMenu.Registrar, com.canonical.Unity, com.canonical.indicator.application,
        org.freedesktop.ScreenSaver, org.kde.StatusNotifierWatcher
    [3] org.freedesktop.UPower
    [4] proprietary
        ID                                Branch         Op         Remote          Download
 1. [✗] org.freedesktop.Platform          24.08          i          flathub             1.0 MB / 261.4 MB
 2. [ ] com.discordapp.Discord            stable         i          flathub         < 112.2 MB
Error: While pulling runtime/org.freedesktop.Platform/x86_64/24.08 from remote flathub: While fetching https://dl.flathub.org/repo/objects/14/c58c475d8a93296f2b1fcc7fa117799621b87b9acff97a82063bc889cfe24d.filez: [56] Failure when receiving data from the peer
error: Failed to install org.freedesktop.Platform: While pulling runtime/org.freedesktop.Platform/x86_64/24.08 from remote flathub: While fetching https://dl.flathub.org/repo/objects/14/c58c475d8a93296f2b1fcc7fa117799621b87b9acff97a82063bc889cfe24d.filez: [56] Failure when receiving data from the pee
This is a network error on your end. Contact your ISP/network operator.
