Can flatpak be used to install existing 32 bit software on 32 it systems ?
I have Debian and after installing flatpak it will not search any apps or install any apps.
And I said in the other thread, 32-bits runtime are no longer supported. That doesn’t prevent flatpak from working, just that there is no software packages for it anymore.
