I’m using Flatpak on Suse MicroOS w/o problems.
However I noticed that some extension exists more than once with different release:
❯ flatpak list | grep gnome.Platform
GNOME Application Platform version 44 org.gnome.Platform 44 flathub user
GNOME Application Platform version 45 org.gnome.Platform 45 flathub user
This means this extension allocates double disk space.
Is there any option to delete the old version and make sure that depending application uses new extension?
❯ flatpak uninstall org.gnome.Platform.Locale
Similar installed refs found for ‘org.gnome.Platform.Locale’:
1) runtime/org.gnome.Platform.Locale/x86_64/44 (user)
2) runtime/org.gnome.Platform.Locale/x86_64/45 (user)
3) All of the above
Which do you want to use (0 to abort)? [0-3]: 1
Info: applications using the extension org.gnome.Platform.Locale branch 44:
org.gimp.GIMP, org.gnome.Cheese, org.remmina.Remmina
Really remove? [y/n]: n
THX
