Hello, I’m trying to compile the glew library, which is a dependency for my flatpak
With this settings
- name: GLEW
- make
- type: git
url: https://github.com/nigels-com/glew.git
I get this error
Building module GLEW in /home/paul/Programming/proyectos/X/platform/flatpaks/ScreenDemo/.flatpak-builder/build/GLEW-6
Switched to branch 'master'
Running: make
mkdir lib
make: *** No rule to make target 'src/glew.c', needed by 'tmp/linux/default/shared/glew.o'. Stop.
Error: module GLEW: Child process exited with code 2
Using this code
- name: GLEW
buildsystem: cmake
# https://github.com/nigels-com/glew?tab=readme-ov-file#using-cmake
- cd build
- cmake ./cmake --target glew_s # Build the static library?
- make -j4
I get this error
Building module GLEW in /home/paul/Programming/proyectos/X/platform/flatpaks/ScreenDemo/.flatpak-builder/build/GLEW-7
Error: module: GLEW: Can't find CMakeLists.txt
How can I compile this library? Tried the instructions from the official documentation
