I am trying to modify the code in the sample electron app.
I get an error and I don’t know what it means. Up to the very end everything works well and I am comforted by the message:
npm timing npm Completed in 2922ms
npm info ok
I get down to the end, and then I get this:
Running: cp -a dist/linux*unpacked /app/main
F: Unexpected filesystem suffix reset, ignoring
Running: install -Dm755 -t /app/bin/ ../run.sh
install: omitting directory '../run.sh'
Error: module TheGuy: Child process exited with code 1
Here I will include my complete yaml file.
app-id: org.theguy.TheGuy
runtime-version: '20.08'
base: org.electronjs.Electron2.BaseApp
base-version: '20.08'
sdk-extensions:
- org.freedesktop.Sdk.Extension.node14
command: run.sh
separate-locales: false
- --share=ipc
- --socket=x11
- --socket=pulseaudio
- --share=network
build-options:
append-path: /usr/lib/sdk/node14/bin
cflags: -O2 -g
cxxflags: -O2 -g
env:
NPM_CONFIG_LOGLEVEL: info
- name: TheGuy
build-options:
env:
# electron_config_cache: /run/build/TheGuy/npm-cache
XDG_CACHE_HOME: /run/build/TheGuy/flatpak-node/cache
npm_config_cache: /run/build/TheGuy/flatpak-node/npm-cache
npm_config_nodedir: /usr/lib/sdk/node14
npm_config_offline: 'true'
subdir: main
- type: dir
path: ..
dest: main
- generated-sources.json
# Wrapper to launch the app
- type: script
dest: run.sh
commands:
- zypak-wrapper.sh /app/main/TheGuy "$@"
# Install npm dependencies
- npm install --offline
# Build the app; in this example the `dist` script
# in package.json runs electron-builder
. ../flatpak-node/electron-builder-arch-args.sh
npm run dist -- $ELECTRON_BUILDER_ARCH_ARGS --linux --dir
# Bundle app and dependencies
- cp -a dist/linux*unpacked /app/main
# Install app wrapper
- install -Dm755 -t /app/bin/ ../run.sh
As you can see, my problem is with the very last of the build commands.
EDIT: One other thing. I needed to build flatpak-builder from source because it was not recognizing my ‘generated-sources.json’ file. I did not specify any special build flags in the ‘./configure’ stage. Might this mess me up? I could not find any online tutorial about building flatpak-builder from scratch.
