Error starting Evolution installed as flatpak
HI All
I switched Evolution from Ubuntu to flatpak source, but when I try start flatpk evolution I get the following error; ‘error: opendir(/): Permission denied’.
I have used the -vv switch the last 3 lines of messages are;
F: Allowing wayland access
F: Allowing pulseaudio access
On the Evolution forum , it was suggested I install another component (Calendar) which I did , but same result
F: Will ensure existence of directory: /home/gc
F: Converting FlatpakExports to bwrap arguments…
F: “/home/gc” is meant to be a directory
F: Ensuring “/home/gc” is created as a directory
F: “/home/gc/.local/share/flatpak” is meant to be a tmpfs or empty directory
F: Parent of “/home/gc/.local/share/flatpak” is not mapped, creating empty directory
F: “/home/gc/.var/app” is meant to be a tmpfs or empty directory
F: Parent of “/home/gc/.var/app” is not mapped, creating empty directory
F: “/home/gc/.var/app/org.gnome.Calendar” is meant to be shared (ro or rw) with the container
as per the Evolution forum , the App should not need access to Root (if opendir(/): is Root).
How do I get more debug information from flatpak?
Thanks
GC
Hey, which version of flatpak are you using?
HI
Flatpak 1.14.6 is the version I have installed
HI
I have some additional testing
gc@gc-black:~$ flatpak run --command=sh org.gnome.Evolution
gc@gc-black:~$ flatpak run --filesystem=host org.gnome.Evolution
same result
gc@gc-black:~$ flatpak -vv run --devel --command=bash org.gnome.Evolution
F: No installations directory in /etc/flatpak/installations.d. Skipping
F: Opening system flatpak installation at path /var/lib/flatpak
F: Opening user flatpak installation at path /home/gc/.local/share/flatpak
F: Skipping parental controls check for app/org.gnome.Evolution/x86_64/stable since parental controls are disabled globally
error: runtime/org.gnome.Sdk/x86_64/48 not installed
gc@gc-black:~$ flatpak install flathub org.gnome.Platform
Looking for matches…
Similar refs found for ‘org.gnome.Platform’ in remote ‘flathub’ (system):
  1. runtime/org.gnome.Platform/x86_64/3.24
  2. runtime/org.gnome.Platform/x86_64/3.26
  3. runtime/org.gnome.Platform/x86_64/3.28
  4. runtime/org.gnome.Platform/x86_64/3.30
  5. runtime/org.gnome.Platform/x86_64/3.32
  6. runtime/org.gnome.Platform/x86_64/3.34
  7. runtime/org.gnome.Platform/x86_64/3.36
  8. runtime/org.gnome.Platform/x86_64/3.38
  9. runtime/org.gnome.Platform/x86_64/40
  10. runtime/org.gnome.Platform/x86_64/41
  11. runtime/org.gnome.Platform/x86_64/42
  12. runtime/org.gnome.Platform/x86_64/43
  13. runtime/org.gnome.Platform/x86_64/44
  14. runtime/org.gnome.Platform/x86_64/45
  15. runtime/org.gnome.Platform/x86_64/46
  16. runtime/org.gnome.Platform/x86_64/47
  17. runtime/org.gnome.Platform/x86_64/48
Which do you want to use (0 to abort)? [0-17]: 17
Skipping: org.gnome.Platform/x86_64/48 is already installed
gc@gc-black:~$ flatpak list --runtime
Name Application ID Version Branch Installation
Freedesktop Platform org.freedesktop.Platform freedesktop-sdk-24.08.22 24.08 system
Mesa org.freedesktop.Platform.GL.default 25.1.3 24.08 system
Mesa (Extra) org.freedesktop.Platform.GL.default 25.1.3 24.08extra system
Intel VAAPI driver org.freedesktop.Platform.VAAPI.Intel 24.08 system
openh264 org.freedesktop.Platform.openh264 2.5.1 2.5.1 system
GNOME Application Platform version 48 org.gnome.Platform 48 system
Yaru-magenta Gtk Theme org.gtk.Gtk3theme.Yaru-magenta 3.22 system
Hi after a long chat with ChatGPT , finally got to what is causing the issue,
[(Understanding AppArmor User Namespace Restriction - Security - Ubuntu Community Hub)
now to work on how to fix it
Thanks
Is the below related to it?
user@user:~$ flatpak run --devel --command=sh org.gnome.Geary
user@user:~$ flatpak install flathub org.gnome.Geary.Debug org.gnome.Sdk.Debug
Similar refs found for ‘org.gnome.Sdk.Debug’ in remote ‘flathub’ (system):
  1. runtime/org.gnome.Sdk.Debug/x86_64/3.24
  2. runtime/org.gnome.Sdk.Debug/x86_64/3.26
  3. runtime/org.gnome.Sdk.Debug/x86_64/3.28
  4. runtime/org.gnome.Sdk.Debug/x86_64/3.30
  5. runtime/org.gnome.Sdk.Debug/x86_64/3.32
  6. runtime/org.gnome.Sdk.Debug/x86_64/3.34
  7. runtime/org.gnome.Sdk.Debug/x86_64/3.36
  8. runtime/org.gnome.Sdk.Debug/x86_64/3.38
  9. runtime/org.gnome.Sdk.Debug/x86_64/40
  10. runtime/org.gnome.Sdk.Debug/x86_64/41
  11. runtime/org.gnome.Sdk.Debug/x86_64/42
  12. runtime/org.gnome.Sdk.Debug/x86_64/43
  13. runtime/org.gnome.Sdk.Debug/x86_64/44
  14. runtime/org.gnome.Sdk.Debug/x86_64/45
  15. runtime/org.gnome.Sdk.Debug/x86_64/46
  16. runtime/org.gnome.Sdk.Debug/x86_64/47
  17. runtime/org.gnome.Sdk.Debug/x86_64/48
    ID                       Branch    Op   Remote    Download
  1. [✓] org.gnome.Geary.Debug stable i flathub 36,3 MB / 40,9 MB
  2. [✓] org.gnome.Sdk.Debug 48 i flathub 4,2 GB / 4,4 GB
Installation complete.
