When I try to run kleopatra I get his error.
flatpak run org.kde.kleopatra
libEGL warning: wayland-egl: could not open /dev/dri/renderD128 (No such file or directory)
kf.dbusaddons: Couldn’t register name ‘local.kleopatra’ with DBUS - another process owns it already!
Operating system: Fedora Kinoite 38
Flatpak version: 1.15.4
Flatpak remotes: fedora , flathub
I earlier had Kleopatra installed from the fedora remote. It worked fine. Then I uninstalled it. After that I installed Kleopatra from flathub. Now it does not open.
hub
April 30, 2023, 11:30am
2
as usually the best way to report problem specific to packages is to file an issue with the package: Issues · flathub/org.kde.kleopatra · GitHub
I was able to get Kleopatra to open
I installed Flatseal
I enabled D-Bus session bus in Flatseal for Kleopatra. I was able to open Kleopatra. The error shown below went away.
Then I enabled GPU acceleration in Flatseal for Kleopatra. The other error shown below went away.
There are differences in the permissions asked for installing Kleopatra from Fedora remote & Flathub remote.
For Fedora remote
org.kde.kleopatra permissions:
ipc network fallback-x11 wayland x11
file access [1] dbus access [2]
[1] xdg-run/gnupg:ro, ~/.gnupg:create
[2] org.kde.StatusNotifierWatcher
ID Branch Op Remote Download
org.fedoraproject.KDE5Platform f38 i fedora < 1.2 GB
org.kde.kleopatra stable i fedora < 7.1 MB
For Flathub remote
[1] xdg-config/kdeglobals:ro, xdg-run/gnupg:ro, ~/.gnupg:create
[2] com.canonical.AppMenu.Registrar, org.kde.KGlobalSettings, org.kde.StatusNotifierWatcher,
org.kde.kconfig.notify
org.kde.kleopatra.Locale stable i flathub < 2.9 MB (partial)
org.kde.kleopatra stable i flathub < 28.9 MB
