Hi there,
Thank you for the potential of this app!!! I am on Ubuntu latest build. I am seeing these errors and doubled check in a browser. Are there updated urls and how do I config them? Thank you again!!
Note: removed plain text password in the error message and the references to https:// so the site would allow me to post:
–snip–
flatpak run io.github.glaumar.QRookie
Note that the directories
‘/var/lib/flatpak/exports/share’
‘/home/chris/.local/share/flatpak/exports/share’
are not in the search path set by the XDG_DATA_DIRS environment variable, so
applications installed by Flatpak may not appear on your desktop until the
session is restarted.
local_queue.json not found
Downloading vrp-public.json from “raw.githubusercontent.com/vrpyou/quest/main/vrp-public.json”
Downloading json Error: "Error transferring raw.githubusercontent.com/vrpyou/quest/main/vrp-public.json - server replied: "
Downloading vrp-public.json from “vrpirates.wiki/downloads/vrp-public.json”
Parsed vrp-public.json: baseUri= “go.vrpyourself.online/” , password= “***”
Downloading: QUrl(“https://theapp.vrrookie.xyz/meta.7z”)
Downloading Error: "Error transferring https://theapp.vrrookie.xyz/meta.7z - server replied: "
Download Metadata failed
Update metadata failed
qt.qpa.wayland: eglSwapBuffers failed with 0x300d, surface: 0x0
