External data checker: how to debug it?
The doc page on the external data checker doesn’t say where we should look if something is not working.
I can run the command on my manifest and I see that a new version is detected.
I hoped it was enough to get the automatic PR working but it’s not.
I’ve introduced the check in this PR. It was merged in master 5 days ago, but flathubbot didn’t create any PR to update the app.
I think I should search some logs on Buildbot… but where?!?
You are using the wrong checker type. Rotating URL checker is for when the URL doesn’t change and always points to the latest version eg. https://example.org/foobar.deb
Use something like this com.vscodium.codium/com.vscodium.codium.yaml at 9e125911020a220c5b2b237b11ae6a3fb09fdef9 · flathub/com.vscodium.codium · GitHub
Thanks, it works.
And I’ve just realized that if I add a couple of options I can verify if the update works (before opening a PR):
flatpak run org.flathub.flatpak-external-data-checker --update --edit-only MANIFEST
