I have installed Remmina with flatpak in an “Installation= Extra” in a secondary partition mounted on /media/user/90gb
The execution is correct, but the program does not save any type of data. Neither passwords, no configurations of any kind.
Some errors at the exit:
Remmina plugin glibsecret (type=Secret) has been registered, but is not yet initialized/activated. The initialization order is 2000.
The glibsecret secret plugin has been initialized and it will be your default secret plugin
(org.remmina.Remmina:2): GVFS-WARNING **: 17:57:22.548: The peer-to-peer connection failed: Error al obtener la información del archivo «/run/user/1000/gvfsd»: No such file or directory. Falling back to the session bus. Your application is probably missing --filesystem=xdg-run/gvfsd privileges.
I have used many applications with FlatPak and I never had this problem. But it is the first time I use an “extra” installation.
I have nothing installed under Flatpak except Remmina (is the first package, in a clean installation Debian 11). I teased to use this secondary partition to host all my FlatPak applications. I do not know if I’m doing something wrong, but any kind of help serves me.
Thanks a lot.
