I followed this guide to set up a local Nginx cache server for Flathub. Everything was functioning well for nearly a year, but it has recently stopped working. Below is my Nginx configuration:
map $status $cache_header {
200 "public";
302 "public";
default "no-cache";
server {
listen 0.0.0.0:8080; # you may want to listen on port 80, or add TLS
server_name my-cache.local; # replace this with your hostname, or system IP
# flathub cache
set $flathub_cache https://dl.flathub.org;
location /flathub/ {
rewrite ^/flathub/(.*) /$1 break;
resolver my-dns.local ipv6=off; # I use my local DNS, but feel free to use whatever you prefer.
proxy_cache flathub;
proxy_cache_key "$request_filename";
add_header Cache-Control $cache_header always;
proxy_cache_valid 200 302 300d;
expires max;
proxy_pass $flathub_cache;
proxy_cache_path /var/cache/nginx/flathub/cache levels=1:2
keys_zone=flathub:5m
max_size=20g
inactive=60d
use_temp_path=off;
I initially had to add resolver my-dns.local ipv6=off;
for it to function correctly.
However, I’m now encountering the error: error: Unable to load summary from remote flathub: Server returned status 421
when trying to install Flatpaks, and I receive F: Warning: Treating remote fetch error as non-fatal ...
when running flatpak update
To update and install Flatpaks, I need to use set $flathub_cache http://dl.flathub.org;
instead of set $flathub_cache https://dl.flathub.org;
, but as I understand it, this results in a redirection to https
on Flathub’s servers, which prevents any caching from occurring. If I bypass the local cache server, Flatpaks installs and updates as expected.
Does anyone have any suggestions on how to resolve this issue?
