Flathub badge in Markdown
This badges page only has HTML and WIKI examples. What is the format sample for GitHub (Markdown)?
You can use the HTML version for that.
It’s what existing projects do, fx:
Thanks, doesn’t look good though
Can you be a bit more specific?
I mean HTML inside of Markdown, not the button haha
[![Alt text](https://flathub.org/api/badge?locale=de)](https://flathub.org/)
Should also work
