our app Cryptomator recieved an update 3 days ago. Due to changes it required an approval, which was done 2 days ago. But the flathub page still doesn’t show the newest version with the updated screenshots. Unfortunately, there seems no way to see when the update will be performed and in the past it only took a day.
Soo, is there a way as a developer to check, if the build process is stuck or if there are any issues?
Thanks for the hints. Unfortunately, the updated version is also not present when using flatpak command (and Discover also still shows the old version).
There is a subtle breakage related to screenshots on our end, but I’m currently busy with other projects. If you update filenames of your screenshots so that the hash of metainfo file changed, they will get updated.
