Bonjour,
Lors de l’installation d’applications, les questions me sont posées en … chinois !
Est-ce possible de changer cela ?
Merci d’avance
82un0
Flatpack en chinois
This should be down to your systems configuration. You might want to double check that and update to the latest flatpak version.
Hello and thank you for your reply,
I’ve done all the updates for Debian 12, and my version of Flatpak is 1.14.10.
