Flatpak build slow on some systems
Gittyup is a gui application for Git and we have since quite a time a flatpak package which is running fine on most systems. Now we have two systems where it does not work properly. It seems that the problem is related to the portals, because loading from disk is really slow:
I created a bug report at flatpak but did not get a response yet and therefore I wanna ask here if someone knows anything about / how to debug it:
flatpak run -v -v com.github.Murmele.Gittyup
F: No installations directory in /etc/flatpak/installations.d. Skipping
F: Opening user flatpak installation at path /home/$USER/.local.kde4/share/flatpak
F: Opening system flatpak installation at path /var/lib/flatpak
F: Cleaning up unused container id 1275106050
F: Cleaning up unused container id 252068050
F: Allocated instance id 1269085740
F: Allowing dri access
F: Allowing homedir access
F: Allowing wayland access
F: Allowing x11 access
flatpak run: Can't find a11y bus: GDBus.Error:org.freedesktop.DBus.Error.TimedOut: Failed to activate service 'org.a11y.Bus': timed out
F: Failed to run in transient scope: No systemd user session available, cgroups not available
F: bwrap --args 31 = --ro-bind /boot /boot --ro-bind /dev /dev --ro-bind /proc /proc --bind /run /run --ro-bind /sys /sys --ro-bind /etc /etc --ro-bind /root /root --bind /tmp /tmp --bind /var /var --ro-bind /usr /usr --symlink usr/bin /bin --symlink usr/sbin /sbin --symlink usr/lib /lib --symlink usr/lib64 /lib64 --ro-bind /media /media --ro-bind /mnt /mnt --ro-bind /opt /opt --ro-bind /srv /srv --ro-bind /users /users --ro-bind /localworkspaces /localworkspaces --ro-bind /config_data /config_data --ro-bind /data /data --ro-bind /MNT_PROD /MNT_PROD --bind /run/user/55897/.dbus-proxy/ /run/user/55897/.dbus-proxy/ --file 28 /.flatpak-info
F: bwrap --args 33 = --fd=32 'unix:abstract=/tmp/dbus-ohTsM4uDC1,guid=9ff25d5c4e545c499c82a3a3647d95df' /run/user/55897/.dbus-proxy/session-bus-proxy-AYD251 --filter '--own=com.github.Murmele.Gittyup.*' '--own=org.mpris.MediaPlayer2.com.github.Murmele.Gittyup.*' --talk=com.canonical.AppMenu.Registrar --talk=org.kde.KGlobalSettings --talk=org.freedesktop.secrets --talk=org.freedesktop.Flatpak --talk=org.kde.kconfig.notify --talk=org.freedesktop.Notifications '--call=org.freedesktop.portal.*=*' '--broadcast=org.freedesktop.portal.*=@/org/freedesktop/portal/*' unix:path=/var/run/dbus/system_bus_socket /run/user/55897/.dbus-proxy/system-bus-proxy-MYD251 --filter --talk=org.freedesktop.UDisks2
F: Running '/usr/libexec/flatpak-bwrap --args 31 /usr/libexec/flatpak-dbus-proxy --args=33'
F: bwrap --args 28 = --ro-bind /home/$USER/.local.kde4/share/flatpak/runtime/org.kde.Platform/x86_64/5.15-21.08/ec3331446a3fb6e8f293a3bc2fae03342cc6732a2d0f8422201241a29e630e18/files /usr --lock-file /usr/.ref --ro-bind /var/lib/flatpak/app/com.github.Murmele.Gittyup/x86_64/development/9d2d2ad1b1231aa46465bb1653671843d6b97589ed94919b67199b8077a7b92e/files /app --lock-file /app/.ref --tmpfs /usr/lib/x86_64-linux-gnu/GL --ro-bind /home/$USER/.local.kde4/share/flatpak/runtime/org.freedesktop.Platform.GL.default/x86_64/21.08/455319fb180e673a05b1156dabba36dd41fd13ccaa71a9fe477710eddbc8f2a0/files /usr/lib/x86_64-linux-gnu/GL/default --ro-bind /home/$USER/.local.kde4/share/flatpak/runtime/org.freedesktop.Platform.GL.nvidia-390-144/x86_64/1.4/f849fcfb9c4a85d8b68267070b8406765f0d361e3f4545f7193e6fde1732b116/files /usr/lib/x86_64-linux-gnu/GL/nvidia-390-144 --ro-bind /home/$USER/.local.kde4/share/flatpak/runtime/org.freedesktop.Platform.openh264/x86_64/2.0/bdc77b1e945ddddcd027dadb9dd93c23437ffc7aca6407b43b385fa1b53a225d/files /usr/lib/x86_64-linux-gnu/openh264 --tmpfs /usr/share/runtime/lib/plugins --ro-bind /home/$USER/.local.kde4/share/flatpak/runtime/org.kde.KStyle.Adwaita/x86_64/5.15-21.08/811d090059b2dbc3a3edd4b3efd3248e92d2922a41faf2fdc0642d4e3249fecd/files /usr/share/runtime/lib/plugins/Adwaita --ro-bind /home/$USER/.local.kde4/share/flatpak/runtime/org.kde.Platform.Locale/x86_64/5.15-21.08/d53910d2eacf91ca26b450ac33208dcca24c99cb7a7e20d9aeb6a8424e17cc35/files /usr/share/runtime/locale --ro-bind-data 11 /run/flatpak/ld.so.conf.d/runtime-001-org.freedesktop.Platform.GL.default.conf --symlink /usr/lib/x86_64-linux-gnu/GL/default/vulkan/icd.d/intel_icd.x86_64.json /usr/lib/x86_64-linux-gnu/GL/vulkan/icd.d/intel_icd.x86_64.json --symlink /usr/lib/x86_64-linux-gnu/GL/default/vulkan/icd.d/lvp_icd.x86_64.json /usr/lib/x86_64-linux-gnu/GL/vulkan/icd.d/lvp_icd.x86_64.json --symlink /usr/lib/x86_64-linux-gnu/GL/default/vulkan/icd.d/radeon_icd.x86_64.json /usr/lib/x86_64-linux-gnu/GL/vulkan/icd.d/radeon_icd.x86_64.json --symlink /usr/lib/x86_64-linux-gnu/GL/default/vulkan/icd.d/virtio_icd.x86_64.json /usr/lib/x86_64-linux-gnu/GL/vulkan/icd.d/virtio_icd.x86_64.json --symlink /usr/lib/x86_64-linux-gnu/GL/default/glvnd/egl_vendor.d/50_mesa.json /usr/lib/x86_64-linux-gnu/GL/glvnd/egl_vendor.d/50_mesa.json --symlink /usr/lib/x86_64-linux-gnu/GL/default/OpenCL/vendors/mesa.icd /usr/lib/x86_64-linux-gnu/GL/OpenCL/vendors/mesa.icd --symlink /usr/lib/x86_64-linux-gnu/GL/default/lib/dri/crocus_dri.so /usr/lib/x86_64-linux-gnu/GL/lib/dri/crocus_dri.so --symlink /usr/lib/x86_64-linux-gnu/GL/default/lib/dri/i830_dri.so /usr/lib/x86_64-linux-gnu/GL/lib/dri/i830_dri.so --symlink /usr/lib/x86_64-linux-gnu/GL/default/lib/dri/i915_dri.so /usr/lib/x86_64-linux-gnu/GL/lib/dri/i915_dri.so --symlink /usr/lib/x86_64-linux-gnu/GL/default/lib/dri/i965_dri.so /usr/lib/x86_64-linux-gnu/GL/lib/dri/i965_dri.so --symlink /usr/lib/x86_64-linux-gnu/GL/default/lib/dri/iris_dri.so /usr/lib/x86_64-linux-gnu/GL/lib/dri/iris_dri.so --symlink /usr/lib/x86_64-linux-gnu/GL/default/lib/dri/kms_swrast_dri.so /usr/lib/x86_64-linux-gnu/GL/lib/dri/kms_swrast_dri.so --symlink /usr/lib/x86_64-linux-gnu/GL/default/lib/dri/nouveau_dri.so /usr/lib/x86_64-linux-gnu/GL/lib/dri/nouveau_dri.so --symlink /usr/lib/x86_64-linux-gnu/GL/default/lib/dri/nouveau_drv_video.so /usr/lib/x86_64-linux-gnu/GL/lib/dri/nouveau_drv_video.so --symlink /usr/lib/x86_64-linux-gnu/GL/default/lib/dri/nouveau_vieux_dri.so /usr/lib/x86_64-linux-gnu/GL/lib/dri/nouveau_vieux_dri.so --symlink /usr/lib/x86_64-linux-gnu/GL/default/lib/dri/r200_dri.so /usr/lib/x86_64-linux-gnu/GL/lib/dri/r200_dri.so --symlink /usr/lib/x86_64-linux-gnu/GL/default/lib/dri/r300_dri.so /usr/lib/x86_64-linux-gnu/GL/lib/dri/r300_dri.so --symlink /usr/lib/x86_64-linux-gnu/GL/default/lib/dri/r600_dri.so /usr/lib/x86_64-linux-gnu/GL/lib/dri/r600_dri.so --symlink /usr/lib/x86_64-linux-gnu/GL/default/lib/dri/r600_drv_video.so /usr/lib/x86_64-linux-gnu/GL/lib/dri/r600_drv_video.so --symlink /usr/lib/x86_64-linux-gnu/GL/default/lib/dri/radeon_dri.so /usr/lib/x86_64-linux-gnu/GL/lib/dri/radeon_dri.so --symlink /usr/lib/x86_64-linux-gnu/GL/default/lib/dri/radeonsi_dri.so /usr/lib/x86_64-linux-gnu/GL/lib/dri/radeonsi_dri.so --symlink /usr/lib/x86_64-linux-gnu/GL/default/lib/dri/radeonsi_drv_video.so /usr/lib/x86_64-linux-gnu/GL/lib/dri/radeonsi_drv_video.so --symlink /usr/lib/x86_64-linux-gnu/GL/default/lib/dri/swrast_dri.so /usr/lib/x86_64-linux-gnu/GL/lib/dri/swrast_dri.so --symlink /usr/lib/x86_64-linux-gnu/GL/default/lib/dri/virtio_gpu_dri.so /usr/lib/x86_64-linux-gnu/GL/lib/dri/virtio_gpu_dri.so --symlink /usr/lib/x86_64-linux-gnu/GL/default/lib/dri/vmwgfx_dri.so /usr/lib/x86_64-linux-gnu/GL/lib/dri/vmwgfx_dri.so --symlink /usr/lib/x86_64-linux-gnu/GL/default/lib/dri/zink_dri.so /usr/lib/x86_64-linux-gnu/GL/lib/dri/zink_dri.so --symlink /usr/lib/x86_64-linux-gnu/GL/default/lib/dri/libgallium_dri.so /usr/lib/x86_64-linux-gnu/GL/lib/dri/libgallium_dri.so --symlink /usr/lib/x86_64-linux-gnu/GL/default/lib/dri/libgallium_drv_video.so /usr/lib/x86_64-linux-gnu/GL/lib/dri/libgallium_drv_video.so --symlink /usr/lib/x86_64-linux-gnu/GL/default/lib/dri/libmesa_dri_drivers.so /usr/lib/x86_64-linux-gnu/GL/lib/dri/libmesa_dri_drivers.so --symlink /usr/lib/x86_64-linux-gnu/GL/default/lib/d3d/d3dadapter9.so.1 /usr/lib/x86_64-linux-gnu/GL/lib/d3d/d3dadapter9.so.1 --symlink /usr/lib/x86_64-linux-gnu/GL/default/lib/d3d/d3dadapter9.so.1.0.0 /usr/lib/x86_64-linux-gnu/GL/lib/d3d/d3dadapter9.so.1.0.0 --symlink /usr/lib/x86_64-linux-gnu/GL/default/vulkan/explicit_layer.d/VkLayer_MESA_overlay.json /usr/lib/x86_64-linux-gnu/GL/vulkan/explicit_layer.d/VkLayer_MESA_overlay.json --symlink /usr/lib/x86_64-linux-gnu/GL/default/vulkan/implicit_layer.d/VkLayer_MESA_device_select.json /usr/lib/x86_64-linux-gnu/GL/vulkan/implicit_layer.d/VkLayer_MESA_device_select.json --ro-bind-data 12 /run/flatpak/ld.so.conf.d/runtime-002-org.freedesktop.Platform.GL.nvidia-390-144.conf --symlink /usr/lib/x86_64-linux-gnu/GL/nvidia-390-144/vulkan/icd.d/nvidia_icd.json /usr/lib/x86_64-linux-gnu/GL/vulkan/icd.d/nvidia_icd.json --symlink /usr/lib/x86_64-linux-gnu/GL/nvidia-390-144/glvnd/egl_vendor.d/10_nvidia.json /usr/lib/x86_64-linux-gnu/GL/glvnd/egl_vendor.d/10_nvidia.json --symlink /usr/lib/x86_64-linux-gnu/GL/nvidia-390-144/egl/egl_external_platform.d/10_nvidia.json /usr/lib/x86_64-linux-gnu/GL/egl/egl_external_platform.d/10_nvidia.json --symlink /usr/lib/x86_64-linux-gnu/GL/nvidia-390-144/OpenCL/vendors/nvidia.icd /usr/lib/x86_64-linux-gnu/GL/OpenCL/vendors/nvidia.icd --ro-bind-data 13 /run/flatpak/ld.so.conf.d/runtime-003-org.freedesktop.Platform.openh264.conf --ro-bind-data 14 /run/flatpak/ld.so.conf.d/runtime-004-org.kde.KStyle.Adwaita.conf --symlink /usr/share/runtime/lib/plugins/Adwaita/styles/adwaita.so /usr/share/runtime/lib/plugins/styles/adwaita.so --proc /proc --unshare-pid --dir /tmp --dir /var/tmp --dir /run/host --dir /run/user/55897 --setenv XDG_RUNTIME_DIR /run/user/55897 --symlink ../run /var/run --ro-bind /sys/block /sys/block --ro-bind /sys/bus /sys/bus --ro-bind /sys/class /sys/class --ro-bind /sys/dev /sys/dev --ro-bind /sys/devices /sys/devices --symlink /etc/timezone /var/db/zoneinfo --ro-bind-data 16 /etc/passwd --ro-bind-data 17 /etc/group --ro-bind-data 18 /etc/pkcs11/pkcs11.conf --ro-bind /etc/machine-id /etc/machine-id --symlink ../../proc/self/mounts /etc/mtab --symlink ../usr/lib/os-release /etc/os-release --ro-bind /home/$USER/.local.kde4/share/flatpak/runtime/org.kde.Platform/x86_64/5.15-21.08/ec3331446a3fb6e8f293a3bc2fae03342cc6732a2d0f8422201241a29e630e18/files/etc/alsa /etc/alsa --ro-bind /home/$USER/.local.kde4/share/flatpak/runtime/org.kde.Platform/x86_64/5.15-21.08/ec3331446a3fb6e8f293a3bc2fae03342cc6732a2d0f8422201241a29e630e18/files/etc/dbus-1 /etc/dbus-1 --ro-bind /home/$USER/.local.kde4/share/flatpak/runtime/org.kde.Platform/x86_64/5.15-21.08/ec3331446a3fb6e8f293a3bc2fae03342cc6732a2d0f8422201241a29e630e18/files/etc/fonts /etc/fonts --ro-bind /home/$USER/.local.kde4/share/flatpak/runtime/org.kde.Platform/x86_64/5.15-21.08/ec3331446a3fb6e8f293a3bc2fae03342cc6732a2d0f8422201241a29e630e18/files/etc/geoclue /etc/geoclue --ro-bind /home/$USER/.local.kde4/share/flatpak/runtime/org.kde.Platform/x86_64/5.15-21.08/ec3331446a3fb6e8f293a3bc2fae03342cc6732a2d0f8422201241a29e630e18/files/etc/gtk-3.0 /etc/gtk-3.0 --ro-bind /home/$USER/.local.kde4/share/flatpak/runtime/org.kde.Platform/x86_64/5.15-21.08/ec3331446a3fb6e8f293a3bc2fae03342cc6732a2d0f8422201241a29e630e18/files/etc/pki /etc/pki --ro-bind /home/$USER/.local.kde4/share/flatpak/runtime/org.kde.Platform/x86_64/5.15-21.08/ec3331446a3fb6e8f293a3bc2fae03342cc6732a2d0f8422201241a29e630e18/files/etc/profile.d /etc/profile.d --ro-bind /home/$USER/.local.kde4/share/flatpak/runtime/org.kde.Platform/x86_64/5.15-21.08/ec3331446a3fb6e8f293a3bc2fae03342cc6732a2d0f8422201241a29e630e18/files/etc/pulse /etc/pulse --ro-bind /home/$USER/.local.kde4/share/flatpak/runtime/org.kde.Platform/x86_64/5.15-21.08/ec3331446a3fb6e8f293a3bc2fae03342cc6732a2d0f8422201241a29e630e18/files/etc/rc_keymaps /etc/rc_keymaps --ro-bind /home/$USER/.local.kde4/share/flatpak/runtime/org.kde.Platform/x86_64/5.15-21.08/ec3331446a3fb6e8f293a3bc2fae03342cc6732a2d0f8422201241a29e630e18/files/etc/ssl /etc/ssl --ro-bind /home/$USER/.local.kde4/share/flatpak/runtime/org.kde.Platform/x86_64/5.15-21.08/ec3331446a3fb6e8f293a3bc2fae03342cc6732a2d0f8422201241a29e630e18/files/etc/xdg /etc/xdg --ro-bind /home/$USER/.local.kde4/share/flatpak/runtime/org.kde.Platform/x86_64/5.15-21.08/ec3331446a3fb6e8f293a3bc2fae03342cc6732a2d0f8422201241a29e630e18/files/etc/e2scrub.conf /etc/e2scrub.conf --ro-bind /home/$USER/.local.kde4/share/flatpak/runtime/org.kde.Platform/x86_64/5.15-21.08/ec3331446a3fb6e8f293a3bc2fae03342cc6732a2d0f8422201241a29e630e18/files/etc/issue /etc/issue --ro-bind /home/$USER/.local.kde4/share/flatpak/runtime/org.kde.Platform/x86_64/5.15-21.08/ec3331446a3fb6e8f293a3bc2fae03342cc6732a2d0f8422201241a29e630e18/files/etc/issue.net /etc/issue.net --ro-bind /home/$USER/.local.kde4/share/flatpak/runtime/org.kde.Platform/x86_64/5.15-21.08/ec3331446a3fb6e8f293a3bc2fae03342cc6732a2d0f8422201241a29e630e18/files/etc/ld.so.cache /etc/ld.so.cache --ro-bind /home/$USER/.local.kde4/share/flatpak/runtime/org.kde.Platform/x86_64/5.15-21.08/ec3331446a3fb6e8f293a3bc2fae03342cc6732a2d0f8422201241a29e630e18/files/etc/ld.so.conf /etc/ld.so.conf --ro-bind /home/$USER/.local.kde4/share/flatpak/runtime/org.kde.Platform/x86_64/5.15-21.08/ec3331446a3fb6e8f293a3bc2fae03342cc6732a2d0f8422201241a29e630e18/files/etc/mke2fs.conf /etc/mke2fs.conf --ro-bind /home/$USER/.local.kde4/share/flatpak/runtime/org.kde.Platform/x86_64/5.15-21.08/ec3331446a3fb6e8f293a3bc2fae03342cc6732a2d0f8422201241a29e630e18/files/etc/moduli /etc/moduli --ro-bind /home/$USER/.local.kde4/share/flatpak/runtime/org.kde.Platform/x86_64/5.15-21.08/ec3331446a3fb6e8f293a3bc2fae03342cc6732a2d0f8422201241a29e630e18/files/etc/nsswitch.conf /etc/nsswitch.conf --ro-bind /home/$USER/.local.kde4/share/flatpak/runtime/org.kde.Platform/x86_64/5.15-21.08/ec3331446a3fb6e8f293a3bc2fae03342cc6732a2d0f8422201241a29e630e18/files/etc/protocols /etc/protocols --ro-bind /home/$USER/.local.kde4/share/flatpak/runtime/org.kde.Platform/x86_64/5.15-21.08/ec3331446a3fb6e8f293a3bc2fae03342cc6732a2d0f8422201241a29e630e18/files/etc/rc_maps.cfg /etc/rc_maps.cfg --ro-bind /home/$USER/.local.kde4/share/flatpak/runtime/org.kde.Platform/x86_64/5.15-21.08/ec3331446a3fb6e8f293a3bc2fae03342cc6732a2d0f8422201241a29e630e18/files/etc/rpc /etc/rpc --ro-bind /home/$USER/.local.kde4/share/flatpak/runtime/org.kde.Platform/x86_64/5.15-21.08/ec3331446a3fb6e8f293a3bc2fae03342cc6732a2d0f8422201241a29e630e18/files/etc/services /etc/services --ro-bind /home/$USER/.local.kde4/share/flatpak/runtime/org.kde.Platform/x86_64/5.15-21.08/ec3331446a3fb6e8f293a3bc2fae03342cc6732a2d0f8422201241a29e630e18/files/etc/ssh_config /etc/ssh_config --ro-bind /home/$USER/.local.kde4/share/flatpak/runtime/org.kde.Platform/x86_64/5.15-21.08/ec3331446a3fb6e8f293a3bc2fae03342cc6732a2d0f8422201241a29e630e18/files/etc/vdpau_wrapper.cfg /etc/vdpau_wrapper.cfg --ro-bind /home/$USER/.local.kde4/share/flatpak/runtime/org.kde.Platform/x86_64/5.15-21.08/ec3331446a3fb6e8f293a3bc2fae03342cc6732a2d0f8422201241a29e630e18/files/etc/wgetrc /etc/wgetrc --ro-bind /home/$USER/.local.kde4/share/flatpak/runtime/org.kde.Platform/x86_64/5.15-21.08/ec3331446a3fb6e8f293a3bc2fae03342cc6732a2d0f8422201241a29e630e18/files/etc/xattr.conf /etc/xattr.conf --bind /home/$USER/.var/app/com.github.Murmele.Gittyup/cache /var/cache --bind /home/$USER/.var/app/com.github.Murmele.Gittyup/data /var/data --bind /home/$USER/.var/app/com.github.Murmele.Gittyup/config /var/config --bind /home/$USER/.var/app/com.github.Murmele.Gittyup/cache/tmp /var/tmp --symlink usr/lib /lib --symlink usr/lib64 /lib64 --symlink usr/bin /bin --symlink usr/sbin /sbin --seccomp 19 --ro-bind /run/user/55897/.flatpak-helper/monitor /run/host/monitor --symlink /run/host/monitor/localtime /etc/localtime --symlink /run/host/monitor/resolv.conf /etc/resolv.conf --symlink /run/host/monitor/host.conf /etc/host.conf --symlink /run/host/monitor/hosts /etc/hosts --symlink /run/host/monitor/timezone /etc/timezone --ro-bind-data 24 /etc/ld.so.conf --ro-bind-data 15 /etc/ld.so.cache --ro-bind /run/user/55897/.flatpak/1269085740 /run/user/55897/.flatpak/1269085740 --lock-file /run/user/55897/.flatpak/1269085740/.ref --file 25 /.flatpak-info --ro-bind-data 26 /.flatpak-info --symlink ../../../.flatpak-info /run/user/55897/flatpak-info --info-fd 27 --bind /run/user/55897/doc/by-app/com.github.Murmele.Gittyup /run/user/55897/doc --dev /dev --dev-bind /dev/dri /dev/dri --dev-bind /dev/nvidiactl /dev/nvidiactl --dev-bind /dev/nvidia0 /dev/nvidia0 --dev-bind /dev/nvidia-modeset /dev/nvidia-modeset --bind /run/user/55897/app/com.github.Murmele.Gittyup /run/user/55897/app/com.github.Murmele.Gittyup --bind /home/$USER /home/$USER --tmpfs /home/$USER/.local.kde4/share/flatpak --tmpfs /home/$USER/.var/app --bind /home/$USER/.var/app/com.github.Murmele.Gittyup /home/$USER/.var/app/com.github.Murmele.Gittyup --bind /tmp /tmp --bind /workspaces /workspaces --ro-bind /home/$USER/.config.kde4/user-dirs.dirs /home/$USER/.var/app/com.github.Murmele.Gittyup/config/user-dirs.dirs --tmpfs /tmp/.X11-unix --ro-bind /tmp/.X11-unix/X1 /tmp/.X11-unix/X99 --ro-bind-data 29 /run/user/55897/Xauthority --bind /tmp/ssh-remQYIKqyI8D/agent.25771 /run/user/55897/ssh-auth --bind /run/user/55897/.dbus-proxy/session-bus-proxy-AYD251 /run/user/55897/bus --bind /run/user/55897/.dbus-proxy/system-bus-proxy-MYD251 /run/dbus/system_bus_socket --sync-fd 30 --bind /run/systemd/journal/socket /run/systemd/journal/socket --bind /run/systemd/journal/stdout /run/systemd/journal/stdout --ro-bind /usr/share/fonts /run/host/fonts --ro-bind /usr/lib/fontconfig/cache /run/host/fonts-cache --tmpfs /run/host/user-fonts-cache --remount-ro /run/host/user-fonts-cache --ro-bind /usr/share/icons /run/host/share/icons --symlink /app/lib/debug/source /run/build --symlink /usr/lib/debug/source /run/build-runtime
F: Running '/usr/libexec/flatpak-bwrap --args 28 gittyup'
QFSFileEngine::open: No file name specified
Does anybody know what I can try out?
