I’m close to creating my first flatpak, which is for a Tkinter application written in Python.
It finishes creating the flatpak successfully, but when I attempt to test the flatpak, I get this error:
_tkinter.TclError: no display name and no $DISPLAY environment variable
Any ideas?
The way I’m attempting to test it is by using this command:
flatpak run org.flatpak.Builder --run build-dir org.lvnauth.LVNAuth.json python3 /app/bin/startup.py
My manifest is:
"app-id": "org.lvnauth.LVNAuth",
"runtime": "org.freedesktop.Platform",
"runtime-version": "22.08",
"sdk": "org.freedesktop.Sdk",
"command": "/app/bin/startup.sh",
"finish-args": [
"--socket=x11",
"--socket=pulseaudio",
"--filesystem=home"
"modules": [
"name": "lvnauth",
"build-commands": [
"install -D startup.sh /app/bin/startup.sh",
"install -D about_window.py /app/bin/about_window.py",
"install -D app_icon.png /app/bin/app_icon.png",
"install -D delete_confirmation.py /app/bin/delete_confirmation.py",
"install -D editor_window.py /app/bin/editor_window.py",
"install -D entrylimit.py /app/bin/entrylimit.py",
"install -D fixed_font_converter_window.py /app/bin/fixed_font_converter_window.py",
"install -D font_sprite_properties_window.py /app/bin/font_sprite_properties_window.py",
"install -D input_ask_new_folder_where.py /app/bin/input_ask_new_folder_where.py",
"install -D input_string_window.py /app/bin/input_string_window.py",
"install -D input_trim_values_window.py /app/bin/input_trim_values_window.py",
"install -D linklabel_widget.py /app/bin/linklabel_widget.py",
"install -D lvnauth_logo.png /app/bin/lvnauth_logo.png",
"install -D new_project_window.py /app/bin/new_project_window.py",
"install -D play_error_window.py /app/bin/play_error_window.py",
"install -D project_snapshot.py /app/bin/project_snapshot.py",
"install -D rect_object.py /app/bin/rect_object.py",
"install -D rect_options_window.py /app/bin/rect_options_window.py",
"install -D startup.py /app/bin/startup.py",
"install -D story_compiler.py /app/bin/story_compiler.py",
"install -D story_details_window.py /app/bin/story_details_window.py",
"install -D wizard_window.py /app/bin/wizard_window.py",
"install -D active_story.py /app/bin/player/active_story.py",
"install -D app_icon_small.png /app/bin/player/app_icon_small.png",
"install -D audio_player.py /app/bin/player/audio_player.py",
"install -D dialog_rectangle.py /app/bin/player/dialog_rectangle.py",
"install -D draft_rectangle.py /app/bin/player/draft_rectangle.py",
"install -D extract_functions.py /app/bin/player/extract_functions.py",
"install -D file_reader.py /app/bin/player/file_reader.py",
"install -D font_handler.py /app/bin/player/font_handler.py",
"install -D launch_window.py /app/bin/player/launch_window.py",
"install -D main.py /app/bin/player/main.py",
"install -D rest_handler.py /app/bin/player/rest_handler.py",
"install -D shared_components.py /app/bin/player/shared_components.py",
"install -D story_reader.py /app/bin/player/story_reader.py",
"install -D about_libraries_window.ui /app/bin/ui/about_libraries_window.ui",
"install -D about_window.ui /app/bin/ui/about_window.ui",
"install -D ask_create_folder_where.ui /app/bin/ui/ask_create_folder_where.ui",
"install -D delete_confirmation_window.ui /app/bin/ui/delete_confirmation_window.ui",
"install -D editor_main.ui /app/bin/ui/editor_main.ui",
"install -D fixed_font_size_converter_window.ui /app/bin/ui/fixed_font_size_converter_window.ui",
"install -D font_sprite_window.ui /app/bin/ui/font_sprite_window.ui",
"install -D input_string_window.ui /app/bin/ui/input_string_window.ui",
"install -D input_trim_values_window.ui /app/bin/ui/input_trim_values_window.ui",
"install -D input_window.ui /app/bin/ui/input_window.ui",
"install -D launch_window.ui /app/bin/ui/launch_window.ui",
"install -D lvnauth_license_window.ui /app/bin/ui/lvnauth_license_window.ui",
"install -D play_error_window.ui /app/bin/ui/play_error_window.ui",
"install -D project_folder_window.ui /app/bin/ui/project_folder_window.ui",
"install -D rect_options_window.ui /app/bin/ui/rect_options_window.ui",
"install -D startup_window.ui /app/bin/ui/startup_window.ui",
"install -D story_details_window.ui /app/bin/ui/story_details_window.ui",
"install -D text_create_dialog.ui /app/bin/ui/text_create_dialog.ui",
"install -D wizard.ui /app/bin/ui/wizard.ui"
"buildsystem": "simple",
"sources": [
"type": "file",
"path": "startup.sh"
"type": "file",
"path": "src/about_window.py"
"type": "file",
"path": "src/app_icon.png"
"type": "file",
"path": "src/delete_confirmation.py"
"type": "file",
"path": "src/editor_window.py"
"type": "file",
"path": "src/entrylimit.py"
"type": "file",
"path": "src/fixed_font_converter_window.py"
"type": "file",
"path": "src/font_sprite_properties_window.py"
"type": "file",
"path": "src/input_ask_new_folder_where.py"
"type": "file",
"path": "src/input_string_window.py"
"type": "file",
"path": "src/input_trim_values_window.py"
"type": "file",
"path": "src/linklabel_widget.py"
"type": "file",
"path": "src/lvnauth_logo.png"
"type": "file",
"path": "src/new_project_window.py"
"type": "file",
"path": "src/play_error_window.py"
"type": "file",
"path": "src/project_snapshot.py"
"type": "file",
"path": "src/rect_object.py"
"type": "file",
"path": "src/rect_options_window.py"
"type": "file",
"path": "src/startup.py"
"type": "file",
"path": "src/story_compiler.py"
"type": "file",
"path": "src/story_details_window.py"
"type": "file",
"path": "src/wizard_window.py"
"type": "file",
"path": "src/player/active_story.py"
"type": "file",
"path": "src/player/app_icon_small.png"
"type": "file",
"path": "src/player/audio_player.py"
"type": "file",
"path": "src/player/dialog_rectangle.py"
"type": "file",
"path": "src/player/draft_rectangle.py"
"type": "file",
"path": "src/player/extract_functions.py"
"type": "file",
"path": "src/player/file_reader.py"
"type": "file",
"path": "src/player/font_handler.py"
"type": "file",
"path": "src/player/launch_window.py"
"type": "file",
"path": "src/player/main.py"
"type": "file",
"path": "src/player/rest_handler.py"
"type": "file",
"path": "src/player/shared_components.py"
"type": "file",
"path": "src/player/story_reader.py"
"type": "file",
"path": "src/ui/about_libraries_window.ui"
"type": "file",
"path": "src/ui/about_window.ui"
"type": "file",
"path": "src/ui/ask_create_folder_where.ui"
"type": "file",
"path": "src/ui/delete_confirmation_window.ui"
"type": "file",
"path": "src/ui/editor_main.ui"
"type": "file",
"path": "src/ui/fixed_font_size_converter_window.ui"
"type": "file",
"path": "src/ui/font_sprite_window.ui"
"type": "file",
"path": "src/ui/input_string_window.ui"
"type": "file",
"path": "src/ui/input_trim_values_window.ui"
"type": "file",
"path": "src/ui/input_window.ui"
"type": "file",
"path": "src/ui/launch_window.ui"
"type": "file",
"path": "src/ui/lvnauth_license_window.ui"
"type": "file",
"path": "src/ui/play_error_window.ui"
"type": "file",
"path": "src/ui/project_folder_window.ui"
"type": "file",
"path": "src/ui/rect_options_window.ui"
"type": "file",
"path": "src/ui/startup_window.ui"
"type": "file",
"path": "src/ui/story_details_window.ui"
"type": "file",
"path": "src/ui/text_create_dialog.ui"
"type": "file",
"path": "src/ui/wizard.ui"
"name": "cpython",
"sources": [
"type": "archive",
"url": "https://www.python.org/ftp/python/3.11.2/Python-3.11.2.tar.xz",
"sha256": "29e4b8f5f1658542a8c13e2dd277358c9c48f2b2f7318652ef1675e402b9d2af"
"name": "flit-core",
"build-commands": [
"pip3 install --verbose --exists-action=i --no-index --find-links=\"file://${PWD}\" --prefix=${FLATPAK_DEST} \"flit-core==3.9.0\" --no-build-isolation"
"sources": [
"type": "file",
"url": "https://files.pythonhosted.org/packages/c4/e6/c1ac50fe3eebb38a155155711e6e864e254ce4b6e17fe2429b4c4d5b9e80/flit_core-3.9.0.tar.gz",
"sha256": "72ad266176c4a3fcfab5f2930d76896059851240570ce9a98733b658cb786eba"
"name": "wheel",
"build-commands": [
"pip3 install --verbose --exists-action=i --no-index --find-links=\"file://${PWD}\" --prefix=${FLATPAK_DEST} \"wheel==0.41.2\" --no-build-isolation"
"sources": [
"type": "file",
"url": "https://files.pythonhosted.org/packages/a4/99/78c4f3bd50619d772168bec6a0f34379b02c19c9cced0ed833ecd021fd0d/wheel-0.41.2.tar.gz",
"sha256": "0c5ac5ff2afb79ac23ab82bab027a0be7b5dbcf2e54dc50efe4bf507de1f7985"
"name": "python3-Pillow",
"build-commands": [
"pip3 install --verbose --exists-action=i --no-index --find-links=\"file://${PWD}\" --prefix=${FLATPAK_DEST} \"Pillow==10.0.0\" --no-build-isolation"
"sources": [
"type": "file",
"url": "https://files.pythonhosted.org/packages/0f/8b/2ebaf9adcf4260c00f842154865f8730cf745906aa5dd499141fb6063e26/Pillow-10.0.0.tar.gz",
"sha256": "9c82b5b3e043c7af0d95792d0d20ccf68f61a1fec6b3530e718b688422727396"
"name": "python3-pygame-ce",
"build-commands": [
"pip3 install --verbose --exists-action=i --no-index --find-links=\"file://${PWD}\" --prefix=${FLATPAK_DEST} \"pygame-ce==2.3.1\" --no-build-isolation"
"sources": [
"type": "file",
"url": "https://files.pythonhosted.org/packages/29/1f/8acc9e552047358688875e7a1ef8f5b5419a7bc5c1eeee3a5beab5a995ff/pygame-ce-2.3.1.tar.gz",
"sha256": "d7eab24aa97ab806e1a3b3d268d0edb8ca3b7ee47f8baa6dbf29d46c39cf3d79"
"name": "python3-pygubu",
"build-commands": [
"pip3 install --verbose --exists-action=i --no-index --find-links=\"file://${PWD}\" --prefix=${FLATPAK_DEST} \"pygubu==0.31\" --no-build-isolation"
"sources": [
"type": "file",
"url": "https://files.pythonhosted.org/packages/46/fd/b7cc00c8ea6d4d2867f6bb94bd2a1e6212f0ad529120666ac6e7b56ffc82/pygubu-0.31-py3-none-any.whl",
"sha256": "b8a177deee56a9686e2a9d2939f4af5e82b27c504bf51c79610d33a8c5b6a04d"
"name": "tkinter",
"build-commands": [
"pip3 install --prefix=${FLATPAK_DEST} ."
"sources": [
"type": "git",
"url": "https://github.com/iwalton3/tkinter-standalone",
"commit": "d9cb97c5bd4f814c73678366e0e48220776b6ad3"
"modules": [
"name": "tcl8.6",
"sources": [
"type": "archive",
"url": "https://prdownloads.sourceforge.net/tcl/tcl8.6.12-src.tar.gz",
"sha256": "26c995dd0f167e48b11961d891ee555f680c175f7173ff8cb829f4ebcde4c1a6"
"subdir": "unix",
"post-install": [
"chmod +w ${FLATPAK_DEST}/lib/libtcl8.6.so"
"name": "tk8.6",
"sources": [
"type": "archive",
"url": "https://prdownloads.sourceforge.net/tcl/tk8.6.12-src.tar.gz",
"sha256": "12395c1f3fcb6bed2938689f797ea3cdf41ed5cb6c4766eec8ac949560310630"
"subdir": "unix",
"post-install": [
"chmod +w ${FLATPAK_DEST}/lib/libtk8.6.so"
