Flatpak does not work in fedora 44
flatpak run rocks.shy.VacuumTube
Running on native Wayland
Passing the following arguments to Electron: --ozone-platform=wayland --enable-wayland-ime --wayland-text-input-version=3
[3 preload-host-spawn-strategy] Failed to let stub process know of exit: Ungültiger Dateideskriptor (errno 9)
Other flatpaks do work. Is there a known way to avoid that error?
it’s not fedora, I’m on the same system and just installed VacuumTube and it seems to work fine. Did you change permissions?
You are right, It was Vacuutube or an dependency. It’s fixed now.
