My app is using gstreamer to play audio & its MPRIS compatible. Locally, it runs fine as long as gstreamer
, gst-plugins-base
& gst-plugins-good
are installed. But in flatpak sandbox there’s no audio output although the track in the app is progressing & is seekable
When run it & play a audio track from the app following errors occur
❯ env -i DISPLAY=:0 flatpak run com.github.KRTirtho.Spotube
(spotube:2): dbind-WARNING **: 08:31:27.958: Couldn't connect to accessibility bus: Failed to connect to socket /run/user/1000/at-spi/bus: No such file or directory
Gtk-Message: 08:31:28.080: Failed to load module "canberra-gtk-module"
Gtk-Message: 08:31:28.101: Failed to load module "canberra-gtk-module"
[ERROR:flutter/lib/ui/ui_dart_state.cc(198)] Unhandled Exception: SocketException: Connection failed (OS Error: No such file or directory, errno = 2), address = /run/user/1000/bus, port = 0
#0 _NativeSocket.startConnect (dart:io-patch/socket_patch.dart:682)
#1 _NativeSocket.connect (dart:io-patch/socket_patch.dart:948)
#2 _RawSocket.connect (dart:io-patch/socket_patch.dart:1805)
#3 RawSocket.connect (dart:io-patch/socket_patch.dart:21)
#4 DBusClient._openSocket (package:dbus/src/dbus_client.dart:768)
#5 DBusClient._connect (package:dbus/src/dbus_client.dart:788)
#6 DBusClient.registerObject (package:dbus/src/dbus_client.dart:674)
#7 new _MprisMediaPlayer2 (package:spotube/services/LinuxAudioService.dart:14)
#8 new LinuxAudioService (package:spotube/services/LinuxAudioService.dart:690)
#9 new Playback (package:spotube/provider/Playback.dart:77)
#10 main.<anonymous closure> (package:spotube/main.dart:45)
#11 _NotifierProvider.create (package:flutter_riverpod/src/change_notifier_provider/base.dart:107)
#12 ProviderElementBase._buildState (package:riverpod/src/framework/provider_base.dart:481)
#13 ProviderElementBase.mount (package:riverpod/src/framework/provider_base.dart:382)
#14 _StateReader._create (package:riverpod/src/framework/container.dart:104)
#15 _StateReader.getElement (package:riverpod/src/framework/container.dart:92)
#16 ProviderContainer.readProviderElement (package:riverpod/src/framework/container.dart:506)
#17 ProviderElementBase.watch (package:riverpod/src/framework/provider_base.dart:732)
#18 ChangeNotifierProvider.create (package:flutter_riverpod/src/change_notifier_provider/base.dart:71)
#19 ProviderElementBase._buildState (package:riverpod/src/framework/provider_base.dart:481)
#20 ProviderElementBase.mount (package:riverpod/src/framework/provider_base.dart:382)
#21 _StateReader._create (package:riverpod/src/framework/container.dart:104)
#22 _StateReader.getElement (package:riverpod/src/framework/container.dart:92)
#23 ProviderContainer.readProviderElement (package:riverpod/src/framework/container.dart:506)
#24 ProviderContainer.listen (package:riverpod/src/framework/container.dart:327)
// ..... (unneeded probably) //
#858 Timer._createTimer.<anonymous closure> (dart:async-patch/timer_patch.dart:18)
#859 _Timer._runTimers (dart:isolate-patch/timer_impl.dart:398)
#860 _Timer._handleMessage (dart:isolate-patch/timer_impl.dart:429)
#861 _RawReceivePortImpl._handleMessage (dart:isolate-patch/isolate_patch.dart:192)
AudioPlayers: Could not query current position.
AudioPlayers: Could not query current duration.
[ALSOFT] (EE) Failed to set real-time priority for thread: Operation not permitted (1)
Here’s the latest manifest if anyone needs it
# yaml-language-server: $schema=https://raw.githubusercontent.com/flatpak/flatpak-builder/main/data/flatpak-manifest.schema.json
app-id: com.github.KRTirtho.Spotube
runtime: org.gnome.Platform
runtime-version: "42"
sdk: org.gnome.Sdk
command: spotube
- --socket=fallback-x11
- --socket=wayland
- --socket=pulseaudio
- --share=network
- --share=ipc
- --device=dri
- --filesystem=xdg-download
- --filesystem=xdg-documents
- --talk-name=org.freedesktop.Notifications
- name: spotube
- install -Dm644 spotube/com.github.KRTirtho.Spotube.appdata.xml /app/share/appdata/com.github.KRTirtho.Spotube.appdata.xml
- desktop-file-edit spotube/spotube.desktop --set-key=Exec --set-value="spotube
%u" --set-icon=com.github.KRTirtho.Spotube
- install -Dm644 spotube/spotube-logo.png /app/share/icons/hicolor/128x128/apps/com.github.KRTirtho.Spotube.png
- install -Dm644 spotube/spotube.desktop /app/share/applications/com.github.KRTirtho.Spotube.desktop
- install -dm755 /app/bin /app/spotube
- cp -R spotube/ /app
- ln -s /app/spotube/spotube /app/bin/spotube
- type: archive
path: Spotube-linux-x86_64.tar.xz
dest: spotube
sha256: <needs fill up>
Download the archive from here and extract it & move Spotube-linux-x86_64.tar.xz
in the same directory as the manifest & get a sha256sum
of the Spotube-linux-x86_64.tar.xz
& past the sha256 hash in the manifest
Please help
