are there plans for a graphical tool to manage flatpak permissions? in gnome software / settings maybe?
for example, to avoid having to use the terminal for Steam players to add HD’s / game partitions with override commands …
for example, to avoid using terminal for Steam players to add HD’s / game partitions with command override …
N
Nick Richards
#2
That’s really a suggestion for GNOME or other environments rather than flatpak per se. Recent versions of GNOME have added Application settings which would absolutely be the place for that - so go and contribute/suggest over there!
T
Martín Abente Lahaye
#3
I prototyped something for that. Will only work with user installation applications, e.g. flatpak --user list --app.
EDIT: it works fine with systems applications now.
