Next, I’m trying to get numpy included. Runtime 21.08.
I get the impression that Cython should be in the Runtime since 20.08. What am I missing?
Error:
Building wheels for collected packages: contourpy, numpy
Running command Building wheel for contourpy (pyproject.toml)
Building wheel for contourpy (pyproject.toml) ... done
Created wheel for contourpy: filename=contourpy-1.1.1-cp38-cp38-linux_x86_64.whl size=19638792 sha256=9913f834f906567db320cf555312a03b84fba2bc399975a6ffb6c1897d4079d0
Stored in directory: /home/jreynolds/.cache/pip/wheels/2f/d0/36/6cd5e4cca51aa4808e0e02b932665f9fabfa0dc5f1d0f46466
Running command Building wheel for numpy (pyproject.toml)
Running from numpy source directory.
setup.py:67: DeprecationWarning:
`numpy.distutils` is deprecated since NumPy 1.23.0, as a result
of the deprecation of `distutils` itself. It will be removed for
Python >= 3.12. For older Python versions it will remain present.
It is recommended to use `setuptools < 60.0` for those Python versions.
For more details, see:
https://numpy.org/devdocs/reference/distutils_status_migration.html
import numpy.distutils.command.sdist
File "setup.py", line 233, in generate_cython
import Cython
ModuleNotFoundError: No module named 'Cython'
The above exception was the direct cause of the following exception:
File "/app/lib/python3.8/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 353, in <module>
main()
File "/app/lib/python3.8/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 335, in main
json_out['return_val'] = hook(**hook_input['kwargs'])
File "/app/lib/python3.8/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 251, in build_wheel
return _build_backend().build_wheel(wheel_directory, config_settings,
File "/app/lib/python3.8/site-packages/setuptools/build_meta.py", line 221, in build_wheel
return self._build_with_temp_dir(['bdist_wheel'], '.whl',
File "/app/lib/python3.8/site-packages/setuptools/build_meta.py", line 207, in _build_with_temp_dir
self.run_setup()
File "/app/lib/python3.8/site-packages/setuptools/build_meta.py", line 258, in run_setup
super(_BuildMetaLegacyBackend,
File "/app/lib/python3.8/site-packages/setuptools/build_meta.py", line 150, in run_setup
exec(compile(code, __file__, 'exec'), locals())
File "setup.py", line 479, in <module>
setup_package()
File "setup.py", line 458, in setup_package
generate_cython()
File "setup.py", line 240, in generate_cython
raise OSError(msg) from e
OSError: Cython needs to be installed in Python as a module
error: subprocess-exited-with-error
× Building wheel for numpy (pyproject.toml) did not run successfully.
│ exit code: 1
╰─> See above for output.
note: This error originates from a subprocess, and is likely not a problem with pip.
full command: /app/bin/python3.8 /app/lib/python3.8/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py build_wheel /tmp/tmplw5azoq8
cwd: /tmp/pip-install-cp9nkz8d/numpy_9317fad06ac04a9393b1f7414ad5fa37
Building wheel for numpy (pyproject.toml) ... error
ERROR: Failed building wheel for numpy
Successfully built contourpy
Failed to build numpy
ERROR: Could not build wheels for numpy, which is required to install pyproject.toml-based projects
Error: module python3-contourpy: Child process exited with code 1
Manifest:
$ less requirements.numpy.json
"name": "requirements.numpy",
"buildsystem": "simple",
"build-commands": [],
"modules": [
"name": "python3-contourpy",
"build-commands": [
"pip3 install --verbose --exists-action=i --no-index --find-links=\"file://${PWD}\" --prefix=${FLATPAK_DEST} \"contourpy\" --no-build-isolation"
"sources": [
"type": "file",
"url": "https://files.pythonhosted.org/packages/b1/7d/087ee4295e7580d3f7eb8a8a4e0ec8c7847e60f34135248ccf831cf5bbfc/contourpy-1.1.1.tar.gz",
"sha256": "96ba37c2e24b7212a77da85004c38e7c4d155d3e72a45eeaf22c1f03f607e8ab"
"type": "file",
"url": "https://files.pythonhosted.org/packages/a4/9b/027bec52c633f6556dba6b722d9a0befb40498b9ceddd29cbe67a45a127c/numpy-1.24.4.tar.gz",
"sha256": "80f5e3a4e498641401868df4208b74581206afbee7cf7b8329daae82676d9463"
"name": "python3-numpy",
"build-commands": [
"pip3 install --verbose --exists-action=i --no-index --find-links=\"file://${PWD}\" --prefix=${FLATPAK_DEST} \"numpy\" --no-build-isolation"
"sources": [
"type": "file",
