Hello All,
I’m new to the group and use the flatpak version of GnuCash and just loaded the Signal Desktop Application on my Fedora37 laptop
Very nice and thanks to those that put this together.
But I have one question. Everything seems to work with no problems but I do get a few errors and don’t know how critical they are.
Gtk Message: Failed to load module “canberra-gtk-module”
Gtk-Message: Failed to load module “pk-gtk-module”
Failed to connect to the bus: Failed to connect to socket /run/dbus/system_bus_socket: No such file or directory
The appropriate libraries (and devel rpm) are installed on the system and the /run/dbus/system_bus_socket does exist. There are no selinux blocks.
I’m curios more than anything else considering the application works as expected. How important are these errors and am I losing any functionality that I may not be aware of?
Regards to All.
