Flatpak updater script doesn't produce a PR
Hi! I am a new maintainer for GitHub - flathub/dev.slimevr.SlimeVR · GitHub , and I am not that experienced in infrastructure around updates. Package has auto updater not-disabled, and workflow run does find a new release for it ( Check if external data changed across Flathub org · flathub/flathub@7cb9cee · GitHub ), but I don’t see auto updater PR being created in the repository.
What is the typical delay?
Also, are there other ways to chat with other maintainers?
Usually it’s one hour.
You can join the chat here https://matrix.to/#/#flathub:matrix.org it’s linked on the website too.
Your “problem” likely is, that you enabled that you only want important/security updates here dev.slimevr.SlimeVR/flathub.json at master · flathub/dev.slimevr.SlimeVR · GitHub
Documentation specifies that it will only trigger update for “important sources”, which can be designated with either is-main-source: true or is-important: true — and we do have a main source…
ty for matrix, will join l8r!
