I want to run a command/binary that is build into a flatpak. I use the command
flatpak run --command=borg com.borgbase.Vorta
also
flatpak run --command=hugin_executor net.sourceforge.Hugin
The problem I’m having is that each of these commands (borg and hugin_executor) require parameters. How do I pass parameters to them? I have tried encasing them in quotes
flatpak run --command=“hugin_executor input.pto” net.sourceforge.Hugin
and without quotes
flatpak run --command=hugin_executor input.pto net.sourceforge.Hugin
neither of these worked.
Does flatpak support passing parameters like this?
