$ flatpak --version
Flatpak 1.12.7
$ flatpak search vlc
F: Failed to parse /var/lib/flatpak/appstream/flathub/x86_64/active/appstream.xml.gz file: Error en la línea 1960, carácter 29:
already set ’
Organic Maps is a free Android & iOS offline maps app for travelers,
tourists, hikers, and cyclists.
It uses crowd-sourced OpenStreetMap data and is developed with love by
’ and tried to replace with ’ (’
Ninguna coincidencia
I am new to flatkpak so any help or hint is appreciated.
I am seeing this too, in Linux Mint 21.1
$ flatpak search libreoffice
F: Failed to parse /var/lib/flatpak/appstream/flathub/x86_64/active/appstream.xml.gz file: Error on line 1960 char 29: <p> already set '
' and tried to replace with ' ('
No matches found
I think this is a bug (syntax error) in the xml file that lists all the flathub applications.
I think a command to update this file might fix it, assuming the error has been corrected by flathub.org people already? However, I tried removing the remote with
$ flatpak remote-delete flathub
and then adding it afresh, with
$ flatpak remote-add --if-not-exists flathub https://flathub.org/repo/flathub.flatpakrepo
But this did not solve the issue. So, I think the issue is with the data at flathub.org, so it will be fixed when the folks there fix the issue, and there is nothing that you I as an end-user can do.
This has been resolved since.
