Getting Flatpak to work
I’m running Debian 13 and attempting to install Steam via flatpak. I have the files in ///home/username/Downloads/ flathub.flatpakrepo and com.valvesoftware.Steam.flatpakref
Flatpak is installed:
flatpak --version
Flatpak 1.16.1
double click on flathub.flatpakrepo
Cannot interact with flatpak resources without the flatpak backend file:///home/samuel/Downloads/flathub.flatpakrepo. Please install it first.
double click on com.valvesoftware.Steam.flatpakref
Cannot interact with flatpak resources without the flatpak backend file:///home/samuel/Downloads/com.valvesoftware.Steam.flatpakref. Please install it first.
This is the first time attempting to use flatpak I must be missing something but for the life of me I don’t know what it is.
Solved.
I found the issue sort of it just worked when I ran the install but it would not before…
These are the notes I made for installing Flatpak on Debian 13 GNOME DE
Install Flatpak:
  1. sudo apt update
  2. sudo apt upgrade -y
  3. sudo apt install flatpak -y
  4. sudo apt install gnome-software-plugin-flatpak -y
  5. flatpak remote-add --if-not-exists flathub https://flathub.org/repo/flathub.flatpakrepo
  6. sudo reboot
NOTE: The URL listed in Debian 12 is deprecated. It has been changed to:
sudo flatpak remote-add --if-not-exists flathub https://flathub.org/repo/flathub.flatpakrepo
also see the Debian Wiki: Flatpak - Debian Wiki
Also recommended Install Flatseal from Software Center.
