Gnote double click on notes does'nt work
Hello All,
I use gnote on my Gentoo, since few time I unable to access to my notes by double click. All notes are available in ~/.local/share/gnote.
I used the 45.2 version and I upgraded the application to 46.1 but the problem persist.
Do you have any idea who can cause this problem ?
Thank you in advance for your help.
Kind regards.
Willy
Can you try, what happens, when you run xdg-open on one of those files in the console? Maybe it logs something useful.
Hi razzeee,
Thank you for your reply, below the result of the command :
Preformatted textwilly@himalaya ~/.local/share/gnote $ xdg-open c705dc3d-91d8-41df-8b44-a9f29e4992f5.note
willy@himalaya ~/.local/share/gnote $ ATTENTION: default value of option mesa_glthread overridden by environment.
console.error: ({})
JavaScript error: resource://gre/modules/XULStore.sys.mjs, line 60: Error: Can’t find profile directory.
console.error: (new TypeError(“a is null”, “resource://gre/modules/components-utils/mozjexl.js”, 1))
JavaScript Preformatted text
this is not meant to work. Notes in that directory are just internal data for Gnote. Back it up, copy the whole directory over, but definitely not meant to be open like a document.
That it worked before is just a coincidence.
