Help packaging up a Flutter app
I’m trying to make a Flatpak of this Flutter app: https://github.com/hamaluik/timecop . I’m using FluffyChat as my inspiration.
There’s one place where I’m getting stuck: I can’t figure out how to include SQLite 3, which the app depends on. FluffyChat seems to accomplish this by including two cmake dependencies: olm and libjsoncpp. Both seem to yield a /usr/lib/x86_64-linux-gnu/libsqlite3.so.0 file, even though neither are directly related to SQLite.
I don’t have a need for any of these libraries, but I do need SQLite 3. How do I do that?
For reference, this is my current Flatpak YAML draft:
app-id: ca.hamaluik.Timecop
runtime-version: '21.08'
command: timecop
separate-locales: false
  - --share=ipc
  - --socket=fallback-x11
  - --socket=wayland
  - --socket=pulseaudio
  - --share=network
  - --device=dri
  - --talk-name=org.freedesktop.Notifications
  - name: timecop
      - cp -R /usr/bin/ /app/timecop
      - mkdir /app/bin/
      - ln -s /app/timecop/timecop /app/bin/timecop
      - ln -s /usr/lib/x86_64-linux-gnu/libsqlite3.so.0 /app/lib/libsqlite3.so
      - install -Dm644 usr/share/ca.hamaluik.Timecop.svg /app/share/icons/hicolor/scalable/apps/ca.hamaluik.Timecop.svg,
      - install -Dm644 usr/share/ca.hamaluik.Timecop.desktop /app/share/applications/ca.hamaluik.Timecop.desktop,
      - install -Dm644 usr/share/ca.hamaluik.Timecop.appdata.xml /app/share/appdata/ca.hamaluik.Timecop.appdata.xml
      - type: archive
        only-arches:
          - x86_64
        path: "timecop-linux-x86_64.tar.xz"
        dest: "timecop"
And this is the error I get:
ln: failed to create symbolic link '/app/lib/libsqlite3.so': No such file or directory
@nedrichards You were offering help with Flutter over at Ideas on growing the Flathub Community in 2022 - #7 by ChrisOfBristol . Could you give me a tip regarding this problem?
You can try to debug your module with flatpak-builder --build-shell=timecop BUILDDIRECTORY MANIFEST. This prepares your build environment for the given module & starts a build shell. There you can manually execute your build-commands & inspect your source directory as well as the /app destination.
You should replace cp -R /usr/bin/ /app/timecop with cp -R timecop /app/timecop to copy your application into the /app-prefix (you’re currently copying the binaries of the SDK into your app).
You have example sqlite3 builds here , here and here
SQLite 3.36 is already part of the Platform (freedesktop-sdk). It shouldn’t be necessary and probably avoided to build it unless a specific or newer version is required.
That’s not why the symbolic link fails, since the library exists (this works: flatpak run --command=ls org.freedesktop.Platform//21.08 /usr/lib/x86_64-linux-gnu/libsqlite3.so.0).
Thanks a ton! Your tip helped me debug he problem. Beside the cp bug that you noted, I also needed to mkdir and then it worked. :slight_smile:
Now I’m dealing with a filesystem permission issue. It seems that both getDatabases() in SQFlite as well as getApplicationDocumentsDirectory() in path_provider point to somewhere outside the sandbox in the home directory. I’ll look into it when I get the time and if I can’t figure it out, I’ll create a new thread.
For now, I’ll be setting the --filesystem=home permission.
I can’t say anything about SQFlite, but getApplicationDocumentsDirectory() resolves into the user visible documents folder (usually $HOME/Documents) and therefore requires --filesystem=xdg-documents.
If you want to hide your files inside $XDG_DATA_HOME, you have to use getApplicationSupportDirectory (this doesn’t require any filesystem-permissions).
References:
path_provider on desktop stores app files in the user’s documents directory
When getApplicationDocumentsPath() is used, call getApplicationSupportPath()
Thanks!
I ended up using XDG_DATA_HOME from xdg_directories. It probably does the same thing, but it was easier to discover for me, and it also seems more future-proof to me.
I also ended up duplicating a file opened from a file picker to a temporary location, though I’m not sure that’s necessary.
I discovered quite late that despite using --force-clean, my binary was not being updated during installation. --disable-cache did the trick.
(My Linux set-up is painful in that my Linux computer has a tendency to randomly freeze up and become unresponsive for hours due to a hardware issue. Other than that, I have a Mac with basically no hard disk space, so VM is out of the question. Testing different builds is quite burdensome, which is why I haven’t tested not copying an imported file to a temp location.)
Anyway, seems like I’m at the finish line. Now just need to make sure that my changes aren’t causing regressions on Android or iOS.
digital ocean is another method if you don’t have workflows working.
You can make a build script and setup an environment and finished within
8 minutes.
You need to choose a droplet that has 4gb of ram. $28 server works… it will cost almost nothing if you destroy the server immediately.
