I recently switched from Windows 11 to KUbuntu and I used Lutris to use the program “Minecraft Bedrock Launcher” from flathub to use Minecraft Bedrock Edition. I have some Minecraft worlds from 1.20 on an SD card that I want to get back into now, but I have no idea where to put the world files so I can play them again.
This forum is more for Flathub and Flatpak as an platform, so not the ideal place to receive support on how to use an specific app.
Most apps have specific help resource. If you look on the app page on the Flathub website, you find links to help resources under “Links”.
As for the Bedrock launcher, they have linked a FAQ there, which contains where worlds are saved:
https://minecraft-linux.github.io/faq/#where-are-my-worlds
