Hi, I just tried following a video about installing Kdenlive on Chromebook, but when I go to the launcher and try and open Kdenlive, it doesn’t open. Anyone know how to properly install Kdenlive on a Chromebook?
Thanks,
Dan
First do Chrome OS Flathub Setup | Flathub
then go to Install Kdenlive on Linux | Flathub and install
i don’t know about kdenlive - if it’s just using disk and screen, it may work.
kdenlive can be a little wonky even on ole ubuntu.
but i waited 6 years to get access to my usb midi devices on chromeos - the linux container won’t let you list them or use them. soooo i threw away my chromebox. i’m much happier with real linux.
You can install normal linux on chromebooks see Turning Chromebooks into regular laptops - media.ccc.de
Thanks for your reply. I had watched another video and hit a snag. I did try your installation and still it wasn’t working. I did email the creator of the video, Chrom OS Made Simple, and he responded with a fix and it worked. Thanks again for your speedy response.
Please document what you did, here
Sure.
First, I went to YouTube and watched this video: How to install Kdenlive on a Chromebook in 2023 (dated 2/9/23) https://youtu.be/L6765lUQn8E?si=mXHFW3v6D4lbY4c4 and followed the instructions which were:
I put these in the address bar:
chrome://flags/#crostini-gpu-support
Then, clicked the drop-down and selected Enabled
chrome://flags/#scheduler-configuration
Then clicked the drop-down and selected Enable Hyper-Threading on relevant CPU’s
I clicked the Restart button to re-boot the chromebook
I enabled Linux by going to Systems setting, Advanced, Developers, and cliked Turn ON button for Linux Developers Environment
I clicked Next and Install to install Linux
I went to the launcher and opened Terminal and used the following commands in this order and clicked enter after each one:
- sudo apt update
- sudo apt install flatpak
- sudo flatpak remote-add --if-not-exists flathub
- https://flathub.org/repo/flathub.flatpakrepo
- sudo flatpak install flathub org.kde.kdenlive
- sudo chown root:root /usr/bin/bwrap && sudo chmod u+s /usr/bin/bwrap
When I went to the launcher, I saw the Kdenlive icon, but when I pressed it, it blinked, but did not open up Kdenlive.
I left a message for the person, Chrome OS Made Simple, who created the video and let them know I was having trouble. The gave me the following to input in the terminal:
flatpak run org.kde.kdenlive
I tried it and it didn’t work. I sent them screen shots of what the terminal said.
They came back and suggested I run this command:
flatpak run --env=QT_QPA_PLATFORM=wayland org.kde.kdenlive
It did work and asked if there was some way to get it where I could click an icon on my screen.
They said I’d have to re-install based on the newest video: How to install Kdenlive 23.08.4 on a Chromebook (dated 2/11/24) https://youtu.be/pZyCK2rHRik?si=crZ33BBJ3uwDRdnX
I had already enabled Linux, so I didn’t need to do that again, although the video walks you through that process in the beginning.
These are the commands from that video
- sudo apt update
- sudo apt install kmenuedit fuse libnss3
- wget https://download.kde.org/stable/kdenlive/23.08/linux/kdenlive-23.08.4-x86_64-A.AppImage
- chmod 755 kdenlive-23.08.4-x86_64-A.AppImage
- ./kdenlive-23.08.4-x86_64-A.AppImage
- kmenuedit
It worked! The program opened and I had an icon in the launcher I could pin to my shelf at the bottom of my screen and click and the program would open.
I hope this has been helpful and what you were asking for. I know this may have been overly detailed, but I am not a techie.
Thanks,
Dan
I understand chromos tries to tell you it can do real thing but come on
Install a real linux on this chromebook and forget chromeOS
Thanks for the comment. As a non-techie, a week ago, Linux wasn’t part of my regular vocabulary. I misspelled it as Linus a couple of times and realized that was the peanuts character on Charlie Brown. I wouldn’t know how to install a “real Linux” or what advantage there would be as the programs I was interested in installing, Kdenlive and Audacity, I now have.
