I am using the Goland flatpak, and in it I want to invoke the rsync installed in my system.
This fails due to a missing shared library:
$ /var/run/host/usr/bin/ldd /var/run/host/usr/bin/rsync
linux-vdso.so.1 (0x00007ffd750cc000)
libattr.so.1 => /usr/lib/x86_64-linux-gnu/libattr.so.1 (0x00007f3cd7c4e000)
libacl.so.1 => /usr/lib/x86_64-linux-gnu/libacl.so.1 (0x00007f3cd7c44000)
libpopt.so.0 => not found
libc.so.6 => /usr/lib/x86_64-linux-gnu/libc.so.6 (0x00007f3cd7a64000)
/lib64/ld-linux-x86-64.so.2 (0x00007f3cd7ef4000)
If I replace this rsync binary with one build statically , it works fine.
Here is the yaml used by the flatpak, no special access to lib files is granted:
app-id: com.jetbrains.GoLand
runtime: org.freedesktop.Sdk
runtime-version: '21.08'
command: goland.sh
separate-locales: false
- --share=ipc
- --socket=x11
- --share=network
- --socket=pulseaudio
- --filesystem=host
- --talk-name=org.freedesktop.Notifications
- --talk-name=org.freedesktop.secrets
- --filesystem=xdg-run/keyring
- --filesystem=xdg-run/gnupg:ro
- --device=all
- --env=GOLAND_JDK=${FLATPAK_DEST}/goland/jbr/
- --allow=devel
- name: goland
- mkdir goland
- tar xzfv goland.tar.gz --directory=${FLATPAK_DEST}/ --strip-components=1
- install -T -Dm644 ${FLATPAK_DEST}/bin/goland.svg ${FLATPAK_DEST}/share/icons/hicolor/scalable/apps/${FLATPAK_ID}.svg
- install -t ${FLATPAK_DEST}/share/applications/ -Dm644 ${FLATPAK_ID}.desktop
- install -t ${FLATPAK_DEST}/share/metainfo/ -Dm644 ${FLATPAK_ID}.metainfo.xml
- icon_in="${FLATPAK_DEST}/share/icons/hicolor/scalable/apps/${FLATPAK_ID}.svg";
icon_out="${FLATPAK_ID}.png"; for s in {32,64,128,256,512}; do rsvg-convert
"${icon_in}" -w "${s}" -h "${s}" -a -f png -o "${icon_out}"; install -p -Dm644
"${icon_out}" -t "${FLATPAK_DEST}/share/icons/hicolor/${s}x${s}/apps/"; done;
- type: file
url: https://download.jetbrains.com/go/goland-2022.1.2.tar.gz
sha256: eb1a09c7a94f15d19786266694482df273307e1f36d900a894472cdde67c66ea
x-checker-data:
type: jetbrains
code: GO
dest-filename: goland.tar.gz
- type: file
path: com.jetbrains.GoLand.metainfo.xml
- type: file
path: com.jetbrains.GoLand.desktop
