Has anyone successfully install OBS Studio? Is there an installation guide? I click on Install and nothing happens.
If you click on install on the Flathub website, it will download a file with the extension .flatpakref.
If you’re using GNOME or KDE, opening this file should open your software manager with the app, where you can then start the installation.
Otherwise, you can start the installation with the following command in your terminal:
flatpak install --from FILE.flatpakref
