How to make a desktoplink to an wine application in flatpak
I installed under the standard prefix in wine a program.
/home/user/.var/app/org.winehq.Wine/data/wine/
in the folder i have an exe
/home/user/.var/app/org.winehq.Wine/data/wine/drive_c/Program Files (x86)/Dud/Dudb/dud.exe
How can i create a desktop icon in linux kdeneon to start the program from the desktop. now i have to start
flatpak run --command=winetricks org.winehq.Wine
Select the stadard prefix, start explorer and klick the path to the exe to start the program. This is very unuseful. Is there a better way to solve this issue?
Greetings
Raffinade
Put:
Exec=flatpak run org.winehq.Wine /path/to/executable
in a .desktop file in ~/.local/share/applications
Wine may have placed one in ~/.var/app/org.winehq.Wine/data/applications that you can copy and modify.
Bottles is a convenient frontend for Wine that can create a desktop entry for you.
you can use https://flathub.org/apps/io.github.fastrizwaan.WineZGUI to import your directory, it will allow you to create shortcuts etc.
This topic was automatically closed after 7 days. New replies are no longer allowed.
