How to obtain go dependencies in a sandbox?
I’ve been working on making a flatpak for OBS Teleport, after a while I was able to come up with this:
branch: stable
runtime: com.obsproject.Studio
runtime-version: stable
sdk: org.freedesktop.Sdk//24.08
sdk-extensions:
  - org.freedesktop.Sdk.Extension.golang
build-extension: true
separate-locales: false
appstream-compose: false
build-options:
  prefix: /app/plugins/Teleport
  libdir: lib/obs-plugins
  append-path: /usr/lib/sdk/golang/bin
  - name: obs-teleport
    build-options:
      build-args:
        - --share=network
      env:
        - GOBIN=/app/bin
        - GOFLAGS="-buildmode=c-shared"
        - GOPATH=/run/build/obs-teleport/go
        - CGO_CFLAGS="-I/app/include/obs"
        - CGO_LDFLAGS="-L/app/lib -Wl,-z,relro,-z,now -Wl,--as-needed -lturbojpeg -lobs -lobs-frontend-api"
      - go mod vendor
      - chmod -R u+w *
      - go build -mod=vendor -ldflags "-compressdwarf=false -linkmode external -X main.version=0.7.4" -v -o "${FLATPAK_DEST}/lib/obs-plugins/obs-teleport.so" .
      - type: git
        url: https://github.com/fzwoch/obs-teleport.git
        tag: 0.7.4
        commit: 3e012bdcde3c8609cc89f1ede6225e30c89451ab
        x-checker-data:
          type: git
          tag-pattern: ^([\d.]+)
      - type: file
        path: com.obsproject.Studio.Plugin.Teleport.metainfo.xml
After that I went to check the flathub submission documents and I see that it requires we add the --sandbox flag. This breaks GO from being able to download it’s dependencies, because it requires I remove
     build-args:
        - --share=network
how is this usually handled? The only thing I’m finding is to source the dependencies ahead of time, download the dependencies ahead of time and then pass the pre-obtained sources in to the builder, which I’m hoping to avoid. Also this is the first flatpak I’ve ever made so if anyone notices something that could be done better please let me know.
Not much experience with Go but with Rust which has a similar problem with dependencies.
From what I understand, the solutions would either be to build from a release tarball that already includes all dependencies (using go mod vendor I think), or to include the dependencies or include the dependencies as part of the flatpak manifest using the approach documented here, which will not pre-download the dependencies, but will tell flatpak-builder where to find them.
Why do you want to avoid that?
Didn’t want to have to pull the source into the repo for the flatpak and wanted to source it via the manifest. That go module tool looks interesting, I’ll try that.
Just finished testing out the example you linked and it worked well :heart:.
