I am trying to build OpenFOAM. https://www.openfoam.com/
The install instruction told to source the given bashrc using source etc/bashrc
which I try below.
OpenFOAM Repo: 3. Setting the Environment | OpenFOAM
However, in the env
command, the environment variable does not show any specific OpenFOAM variable, which I guess that it does not work.
I would like some suggestion. Thank you.
app-id: com.openfoam.OpenFOAM
runtime: org.freedesktop.Sdk
runtime-version: 22.08
command: openfoam
- --share=ipc
- --device=dri
- name: openmpi
cleanup:
- /bin
- type: archive
url: https://download.open-mpi.org/release/open-mpi/v4.1/openmpi-4.1.4.tar.bz2
sha256: 92912e175fd1234368c8730c03f4996fe5942e7479bb1d10059405e7f2b3930d
- name: OpenFOAM
- source etc/bashrc
- env
- ./Allwmake
- type: archive
url: https://dl.openfoam.com/source/v2212/OpenFOAM-v2212.tgz
sha256: 0a3ddbfea9abca04c3a811e72fcbb184c6b1f92c295461e63b231f1a97e96476
