I need help with sober
Hello I am very new to linux and I had sober roblox working and running amazing until I messed with the json file and I have no Idea what that is, on the website it says if you delete the file it will reset it but ive unistalled sober multiple times and whenever I try to run it, it says theres a typo in the json file, I am on cachyos so basically arch. Any help would be awesome.
please anyone im really struggling with this ive been trying all day to fix it
Just on a general note:
This forum is more about Flathub as a platform. Its not the best place to get help for specific apps. You can find links to specific help resources for an application on its app page on Flathub.org. Look for the Links section of the page, you can find links to help pages and issue trackers for the app there.
Anyways, that aside:
The data folder for an Flatpak is not automatically removed if you uninstall it. GNOME Software will ask you if you want to remove the data, KDE Discover will not remove the data itself. If you use Flatpak in the Terminal, you should add --delete-data to remove that folder, such as:
flatpak uninstall --delete-data org.vinegarhq.Sober
thank you so much, people like you are the reason I love linux
